Is there a way to turn off the seat belt beeper
Discussion in 'Gen 2 Prius Main Forum' started by dpguest, Mar 2, 2008.
  1. dpguest
    dpguest New Member
    16
    Somers, NY
    My dog loves to ride in my brand new prius. Most of the time she stands on the console so she can see out, but every so often she sits down on the seat and the seat belt signal goes on and on and on....
    Is there any way to turn the danged thing off?
    thanks
  2. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    Yes, do a search for seat belt beep. Its been a while since I've seen it, but I turned mine off the day after I got my car. I'll try to find it and post the link here. It beeps exactly 50 times by the way :D
    **Edit** I just did the search, and there are approximately 84 threads about disabling the seat belt beep. The search feature is you friend. Pick one and turn that sucker off!!
  3. hill
    8,188
    Here's a cut and paste from another post:
    (but now you have to do 10 searches for others :p )
    Seatbelt Beep On/Off:
    1. Power on the car to IG-ON or READY. IG-ON will do for this purpose.
    2. Using the Trip/ODO button, set the Trip/ODO display to ODO (not Trip A or Trip :cool:
    3. Power off the car.
    4. Now power the car to READY (brake on). This is required so that step 6 works correctly.
    5. Within 6 seconds of powering on, press and hold the Trip/ODO button for 10 seconds or more.
    6. WHILE STILL HOLDING ODO *after* the 10 seconds, buckle then unbuckle the appropriate seatbelt
    while continuing to depress the Trip/ODO button. Now release the Trip/ODO button.
    7. If the last step was successful, "b on" or "b off" should be displayed in the location where the Trip Odometer or Odometer is normally displayed. "b on" is beep on, and "b off" is beep off.
    8. Press Trip/ODO to toggle the mode.
    9. Now power the car off to exit the toggle mode.
    10. Power the car on to READY and confirm the seatbelt beep status
    The beep should not be audible if "b off" was selected, and should be audible if "b on" was selected..
  4. removeum
    removeum Member
    407
    El Paso, TX
    :cool: Why not just put the seatbelt in the buckle? Problem solved or get a pet attachment from Pets-Mart and buckle the puppy in for safety.
  5. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    Although the beeper can be disabled, the warning light on the dash still continues to flash.
    I didn't like the idea of connecting the passenger seat belt to get it to stop (it tends to interfere with anything in the seat). So, I simply went down to my local Toyota dealership and ordered a seat belt extension. They come in three different lengths (6", 9", and 12", I think) and there's no charge.
    I got the shortest one, inserted it, and no longer have either the beeper or the flashing dash light whenever I put anything onto the passenger seat.
  6. captnslur
    captnslur Junior Member
    78
    Lake Crystal, Minn
    I shudder to think that you are carrying your pet on the passenger seat next to you in your Prius or in any car/truck. You place the pet in great danger by not having it restrained, just like any other precious cargo.
    The best place for any pet is home in the kitchen, not unrestrained in the car, especially in the front seat. The danger, of course, is from the deployment of the air bag should you have a crash.
    Please, please, please check into a pet restraint harness. They are quite comfortable for the pet and are designed to retain the pet in the back seat. Attaching to the diagonal belt in the back seat, they allow the pet to move around bit and fido will not become a missile if the car should crash. Please check into that for your pet's sake. :eek:
  7. Rangerdavid
    1,362
    52
    Three Touring
    EXCELLENTadvice!!! :rockon:
  8. Flying White Dutchman
    4,374
    313
    best is to buckle up:D then sound go's away
  9. captnslur
    78
    Lake Crystal, Minn
    Thank you RangerDavid.
    The airbag is a wonderful safety device, but can be very dangerous if not used properly. Most of us don't realize the potential risk of ignoring that air bag. Placing "stuff" on the passenger side dash board can put passengers in danger also. GPS units, clip boards or other objects placed over the airbag on the passenger side exposes passengers to unneccessary risk should the car crash severely enough to deploy the air bag. That "stuff" would be forcefully driven back into the passenger. For the same reason, one should never travel with your feet resting over the glove box and onto the dash board. One can note the slight indentation in the material covering the air bag module there. It's a good idea to keep that area free of "stuff' when traveling.
