Is there an accelerator problem in the Prius independent of floor mats?
Discussion in 'Gen 2 Prius Main Forum' started by odysseus, Dec 14, 2009.
  1. odysseus
    odysseus Junior Member
    61
    Austin, TX
    My wife is worried about buying an '06 Prius if there's an accelerator pedal problem that is independent of floor mat positioning.
    Can anyone reassure me/us about this? I thought that the problem was solely related to the floor mat coming in contact with the accelerator, and that without a driver's side floor mat, there would be no problem.
    Has anyone here experienced a sudden acceleration problem in a Prius?
  2. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 Prius has 165,000 miles - no accelerator problems. I had a dangerous acceleration problem in my 1980 Datsun (Nissan) 510 due to a carburetor manufacturing problem, so it can happen in any car.
    JeffD
  3. odysseus
    61
    Austin, TX
    Thanks! What about this, though?
  4. Tripod137
    Tripod137 New Member
    145
    Long Island
    That's based on non-OEM floormats (and probably a few OEM floormats) not installed correctly by the user.
    I have a '06 and had the accelerator problem. Solved it by installing the mat correctly.
  5. odysseus
    61
    Austin, TX
    I found this tabulation to be most helpful, which shows that the 2004-2009 Prius is ranked 13th in NHTSA accelerator complaints.
    It's a problem with many modern cars, probably not solely related to floormats. Some user error with the accelator/brake pedal, and perhaps some involve the cruise control.
  6. fuzzy1
    10,150
    I don't think anyone can answer your question with any certainty. If there is an underlying problem, it is masked by the much more frequent floor mat errors and driver pedal-misapplication errors. I've done the later is a previous car, not a Toyota.
    Note that if there is a problem, it is not a Prius-specific problem, but rather a problem throughout the modern Toyota-Lexus product line.
    The upcoming recall should eventually allow us to determine whether or not another real problem exists, but it may take several years. Remember that this same issue hit the Audi 5000 a quarter century ago, and nothing beyond 'driver error' was ever demonstrated.
    Meanwhile, I'm not worried. If a problem exists, it is so rare that the risk is very small compared to my overall driving risk, and I'm still much safer in my Prius than in the older car it replaced.
    If a problem occurs, the best response is to shift to Neutral. If your wife is coming from a manual transmission, as I did, this should be a very natural action. The very few claims I've heard about Toyotas refusing to shift to Neutral were in non-hybrids, and even those claims have not been backed up.
    If your wife is one of the many people who has driven only automatic transmissions and has never shifted to Neutral, then it is time to learn. Even if she does not drive a Toyota.
  7. oms2burn
    oms2burn New Member
    53
    Midwest
    I had an incident where my pedal stuck on my 2006 Prius...I was being a moron and floored it trying to show off my new car and how "fast" (not) it went (although I am still impressed by the low end torque). I had the original mats in (and were installed correctly). I just did the same thing I have done with other cars in the past: Put my foot under the gas pedal and pulled back. Problem fixed (except for embarrassment). If they do anything with this recall, I might mention it to the dealer, but beyond mentioning it to the family drivers, I doubt I will do anything.
  8. odysseus
    61
    Austin, TX
    So the Prius will shift to neutral when one is actually in motion? Because I read an account according to which it wasn't possible on a Prius.
  9. fuzzy1
    10,150
    That is garbage. I've done it many times, as have many others on this forum.
    When I push the stick to N at highway speed, there is a delay of about one second before it actually goes Neutral, much less than the 3 second Power Off delay. (I haven't personally tried powering off while in motion.)
    When I push the stick to R at highway speed, it does the Right Thing -- it immediately goes Neutral with a double beep warning. No exploding transmission.
    The Prius manual says to not shift to Neutral while moving forward, in order to prevent possible damage. It seems that this risk is a corner case, triggered only when shifting while below 41/46 mph (depending on model year) with the gasoline engine not spinning, then rolling down a steep hill to a higher speed that spins MG1 beyond its safe mechanical limits.
    This damage mechanism is not possible on level ground, or when the gas engine is spinning, such as during an engine surge. And even if it was possible, so what? It would still be a much better outcome than flying off a road or into an obstacle at highway speed.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You can read all sorts of rubbish about Prius and how they will cause the end of civilization as we know it. Seriously, you can't believe random allegations or you will end up wearing a tinfoil hat.
    Tom
  11. richard schumacher
    7,663
    1,038
    United States
    Wait, what? If it wasn't the mat, then what was the pedal stuck on? Or are you saying that the pedal was stuck on the mat *with the mat in its intended location*? That would be serious.
  12. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    My wife and I have driven 500,000 miles since 2000 in 6 different Toyota's. Not a one has ever shown any inkling of unforeseen acceleration. To us it's a non-issue ( as are the mats ) so we intend to continue to put 50,000 mi/yr on our current and next Toyotas.
    My 2005 Prius now has 135,000 miles on it. Other than being a deer target nothing unforeseen of any nature has occured..:(.
  13. oms2burn
    oms2burn New Member
    53
    Midwest
    I'm saying the mechanism jammed (no mat was involved in the harming of this human). Maybe my foot was more on the side of the pedal...maybe they forgot to put enough grease on the throttle mechanism. My point is to train people to pull back on the pedal as a first thing to try. Yes, a neutral shift is important too. Whichever you think of first and/or gets you out of trouble.
  14. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    I can't believe this conversation is really happening
  15. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Agreed.
    Yes you can and I've done it many times (but at low speeds only, so far). The latter statement is rubbish. You might find Luscious Garage | Blog | Floor mat anxiety? LG TV investigates… informative.
  16. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    08 with 40K miles.
    zero problems, zero drama
  17. philobeddoe
    575
    107
    Los Angeles
    i've done it ...
    i've hit Neutral, Reverse and Park, starting at 2 mph, and working up to 80 mph at 5 mph intervals
  18. bac
    bac Active Member
    863
    52
    Pennsylvania
    -Brad
  19. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    People will always blame someone else. The poster that mentioned the "maybe her knee touched the cruise control" was at least being honest with himself and everyone else. Too often we do things that we just don't realize and it cause these events to happen. The NTSA has been unable to recreate the acceleration event so there must be some room for operator area here.
    I had 50k on my 05 and just over 5k on my 10. I have never had an unintentional acceleration issue with any car, although snow and ice in Vermont can clog up your pedal area in the winter.
  20. richard schumacher
    7,663
    1,038
    United States
    And when you took it to a dealer what did they find? If the mechanism jammed, it's broken and needs to be fixed.
    I'm willing to believe that yours is damaged or was assembled incorrectly. In the absence of more info I don't believe that it has a design flaw, because lots of people have been looking at this for a while now and reported no such thing.
