Is there any difference between 04000-32528 and G9020-47031 inverter pump?
Discussion in 'Gen 2 Prius Technical Discussion' started by 502_Prius, Nov 18, 2018.
  1. 502_Prius
    502_Prius New Member
    Strangeland
    ]Hello priuschat!
    I have a pretty "simple" question for you knowledgeable guys, is there any significant difference in functionality between 04000-32528 ($50) and G9020-47031 ($80+) inverter coolant pump? Difference in price online is $30+ but both lists compatibility with 2004-2009 Prius. It's for a 2007 G2 Base.
    Thank you :)
  2. 502_Prius
    Strangeland
    Anyone? I asked my local dealer outside the US and they want US$240 for the G9020-47031. lol
  3. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    There was a recall on the inverter pumps some time ago. Could one of those be the old bad pumps?
    502_Prius likes this.
  4. 502_Prius
    Strangeland
    I don't really know :(
  5. Elektroingenieur
    2,515
    3,258
    Three Touring
    As @Skibob kindly notes, there was a recall, and the recall work instructions (PDF) say on page 3 that part number 04000-32528 is a kit consisting of the G9020-47031 pump plus a gasket, part number 90430-18008. The gasket is to replace the non-reusable gasket on the drain plug, which must be removed to drain the coolant before replacing the pump.
    Skibob and 502_Prius like this.
  6. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    ^ B-I-N-G-O! The kit makes it easy all you need in addition to the pump kit is some SLLC. A gallon should be more than enough for the inverter pump replacement as I recall. But for $30 I bet you can source the drain plug crush washer more cost effectively. Your choice.
  7. 502_Prius
    Strangeland
    Thank you very much guys, I just did the HVAC Coolant Control Valve change yesterday so I drained the coolant and put new one in, I'm planning ahead with the inverter pump so it will not fail on me when I need the car and definitely will do the coolant change since I don't know when it was done since I purchase the car. I will buy that kit whenever possible :)
    Cheers.
    Elektroingenieur and audiodave like this.
