is there any way to test the HV battery by Techstream ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Abdulaziz_Barham, Nov 15, 2016.
  1. Abdulaziz_Barham
    Abdulaziz_Barham Junior Member
    68
    Jordan-Amman
    Three Touring
    Hi all
    or how i can do cell by cell test ??
    to know which are the weak of them and how to replace it
    (do it myself)
    thank you in advanced
  2. dolj
    dolj Senior Member
    7,487
    3,763
    Wellington, New Zealand
  3. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    FOR THE MANUAL TEST ARE LIKE THESE STEPS ??
    1-remove the HV batt
    2-test each cell by avometer
    3-empty each cell by Bulb
    4-re-test each cell again by avometer
    5-then rearrange or replace the weak cell
    6-and clean the cooper
    is these steps are right ??
    i do not need to charge the batt by home cable 220 v ??
    Please help me to understand it
  4. Dimkaps54
    Dimkaps54 New Member
    16
    Greece
    You cant charge the battery like this . Dont try this alone because there are certain values that u must not drop below of the battery , and a certain way to charge it. Also be carefull of the high voltages they can cause death ..
  5. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    No. Those are wrong.
    You need to at least measure the loaded voltage to determine the internal resistance. Also you should really measure the capacity as well. There are many ways to do it including measuring it with the pack still connected together.
    PS: What you are talking about is module. Other people also call them cells by mistake. There is 6 cells (in series) inside every module and then 2 of those modules are connected together (in series) to form a block. And then 14 of those blocks are connected in series to form a whole pack.
  6. Dimkaps54
    16
    Greece
    Hi Valde3 , I saw you are familiar with the techstream and hv batteries so i have some quetions , i would be grateful if you could help me. When checking the voltages of an HV battery lets say of a prius or a lexus , and u notice block 1 is problematic . How do u identify block 1 (2 modules) when u have the battery opened in front of you ?
  7. valde3
    2,002
    745
    Finland
    Unfortunately depending on the model it can change. On some it’s the one on control unit end and on other just the other end. Best is to actually measure the modules.
  8. Dimkaps54
    16
    Greece
    I know they change from model to model that's the problem , do u know a way to check which block is 1 each time ? It's not mentioned to manuals.
