Is there anything I need to be aware of before buying a used Prius?
Discussion in 'Gen 2 Prius Main Forum' started by hemingways, Jul 31, 2015.
  1. hemingways
    hemingways New Member
    Chicago
    I'm looking at a used 2005 Prius with 180,000 miles on it. It's 1 owner. It had a new battery installed from Toyota a couple of months ago and a transaxle also installed from Toyota last month. The car seems perfect. The price is good, at market price. I do not see anything wrong with it and it drives great. I'm ready to buy it but wanted the experience of all of actual Prius owners, is there anything else I should be aware of or look for before purchasing it? I know it's a used car and it's not bulletproof, no used car is, but the piece of mind and wallet knowing the battery was replaced is good. Is the fact that it had any problems with the CVT at all something to be concerned with? The dealer showed me the receipts for both and I talked to Toyota and verified everything is on the up and up. I forgot to ask Toyota if the new battery has any warranty though.
    I'm sure there are a lot of posts like this, I appreciate any responses. Thank you.
  2. JC91006
    16,480
    8,397
    You have a receipt from Toyota for the HV battery and transaxle? That should be around $8000
    I'm not sure what the market value is, but if both items replaced by an official Toyota dealer. I would buy it in a heartbeat
  3. hemingways
    Chicago
    I have a copy of paperwork for the battery and the receipt for the transaxle. The owner traded it in and the dealer performed both after the trade in. I do not have a receipt of the battery replacement, just a print out showing it was replaced along with other work and the service records from Toyota online show it was replaced as well.
  4. JC91006
    16,480
    8,397
    there are 2 batteries in the Prius, one is just a $200 12v battery, the other one is a $3000 HV battery
  5. hemingways
    Chicago
    I know, this is the main battery, not the 12v.
    The service records on the Toyota owner website shows exactly what the paperwork at the dealer shows:
    MISC, PERFORM MULTI-POINT INSPECTION AND PROVIDE REPORT, BATTERY NEW - HYBRID: BIG ONE UNDER REAR SEAT (169580027), DRIVE BELT (169581780)
    and
    REPLACED THE TRANSAXLE
  6. JC91006
    16,480
    8,397
    The dealership must've gotten the car for free to invest that much money in it. How much is the market price?
  7. Kate Harvest
    Kate Harvest Member
    105
    Vancouver, WA
    Those are the two main things that can be a costly headache if they fail on you. Take a moment to verify you can see movement in the Inverter cooling reservoir when the car is on and that there aren't any huge pink coolant stains near the engine coolant pump indicating leaks (just look near the lower pull on the one belt on the passenger side)... Check the voltage the 12v is putting out...
    But even if both coolant pumps *and* the 12v were on their way out, that'd at most be reason to get a few hundred bucks knocked off the price, not reason to avoid buying a car with a brand new HV pack and transaxle.
    hemingways likes this.
  8. hemingways
    Chicago
    $6000. It's 180k. Nice condition. The battery being replaced was a big plus for me but the transmission being replaced, and with a used one, kind of has me wondering.
  9. JC91006
    16,480
    8,397
    if the car drives good, it's worth $6000.
    Yes there can be failures of BOTH hv battery and transaxles at that mileage. Everything else seems pretty minor compared to those 2 repairs. Keep in mind the car was only designed to go 180k miles. But....the 2 most costly failures have been replaced.
  10. hemingways
    Chicago
    Thanks I'll check those. With those two things replaced this seems almost like a no brainer to me, just wanted other opinions, especially with the transaxle. From what I understand, that's not a terribly common thing to have issues with on the Prius?
  11. hemingways
    Chicago
    Thanks.
  12. JC91006
    16,480
    8,397
    Older Prius cars tend to burn oil, so you have to pay attention to that as well.
    I replaced my transaxle on my 2005 at 150k miles....so it's not unheard of
  13. JC91006
    16,480
    8,397
    The more likely scenario here is the dealer got the trade for next to nothing. Then the service manager pulled some strings to have the items replaced under some type of warranty.
  14. hemingways
    Chicago
    You're probably right.
  15. JC91006
    16,480
    8,397
    So what model Prius is this? Does it have smart key and backup camera?
    There should be a standard 1 year warranty on all replaced parts
  16. hemingways
    Chicago
    Smart key, no backup camera. Toyota owner service website only says 2005 Toyota Prius STD, Carfax only says 2005 Toyota Prius. Which model number would that be?
  17. JC91006
    16,480
    8,397
    actually 2005 doesn't have a reverse camera.
    if it has a smart key (where you don't have to put it in a slot to start), that's at least a Prius II. Then there's the audio add on, navigation, curtain air bags, etc to add to other packages.
  18. hemingways
    Chicago
    It has navigation. Radio seems fine but I have no idea what to look for it it's an upgraded package version. Seems like a really nice car.
  19. JC91006
    16,480
    8,397
    I have a chart at home that identifies the models and equipment. If the car has Navigation it's a pretty nicely equipped model. It drives fine? Do you get a 30 day warranty with the car?
  20. hemingways
    Chicago
    No warranty, it's as-is, just a small dealer. And the miles are too high to buy any extended warranty anyway.
