Is there much of a difference between an '05-'06 and an '09 Prius?
Discussion in 'Newbie Forum' started by jbirdawg, May 5, 2017.
  1. jbirdawg
    jbirdawg Junior Member
    53
    Atlanta, GA
    I am looking to buy a Prius for my college aged son and don't want to spend over $7500. I have found a 2009 w 71K on it for $7250. The tax will take it over 7500 a bit. Also found a 2006 w 81K 1 owner and new tires for $5999. Just wondering if there is much of a difference in the base models with similar mileage. Both cars are in fine shape. Thanks
  2. ETC(SS)
    6,563
    You need to dig a little deeper than just years and mileage, but the answer to your question is "not much."
    Service history?
    Carfax?
    Traction battery?
    Both cars will need AT LEAST some comprehensive maintenance (not to be confused with repairs) in the next few years.
    What's the plan for that?
  3. Tideland Prius
    16,159
    There were a few things removed in 2008 to offer a lower MSRP (and that carried over to 2009) so a base 2009 may not have cruise control or heated mirrors etc compared to a base 2006. (If it really is a base model. I'm not sure how many were actually sold without cruise control).
    However, side and side curtain airbags were made standard in 2007 and a Gen 2 Prius fares better with the side/side curtain airbags so the 2009 would have it but not the 2006 (unless it was chosen with a package with side and side curtain airbags)
    RCO likes this.
  4. Moving Right Along
    Moving Right Along Senior Member
    690
    541
    With prices, it's also helpful to consider that the Prius is a poor seller right now, so you may be able to negotiate a decent discount. When I bought my 2009 Prius last December, I got it for $400 less than the advertised price with hardly any effort at all.
    From the studies I've seen, there's a drop in battery failure rates from the 2008 model year and more recent (from around 3% to less than 1%). Other than that, comparing the cars would be best in person doing test drives for each. That way, you also get to see what features each car really has, as ads are sometimes mistaken or forget things.
    RCO likes this.
  5. bisco
    49,514
    welcome!
    i would go with the '09. the extra safety features and newer mechanicals make the extra $1250. worthwhile. and you'll get good service from it, and recapture the extra money if you sell.
    the '06 battery could die at any time.
    all the best!(y)
    RCO likes this.
  6. jbirdawg
    53
    Atlanta, GA
    Thanks, folks! I just started researching Prius yesterday as my son wants one. I posted the question assuming carfax and service, etc. were all similar. I don't know anything about a "traction battery", or "comprehensive maintenance". Could you all educate me on what to know and expect. I will definitely be taking it in to Toyota to check out before purchasing. Surprised to hear the '06 battery may fail at anytime based on my short research. What is a Generation 2 Prius?
    RCO likes this.
  7. jbirdawg
    53
    Atlanta, GA
    What did you pay, if I may ask, and what mileage?
  8. Tideland Prius
    16,159
    It's a 2nd generation (2004-2009).
    Well @bisco is a bit overdramatic. Technically, any of our batteries "could die at any time" lol. But on the plus side, that means a relatively new car if you replace the battery (but you would almost never replace an engine in regular car cause an engine costs waay more than a battery).
    RCO likes this.
  9. Moving Right Along
    690
    541
    Advertised price was $8000 for 2009 Prius in very good condition with reverse camera, aux. port, floor mats, & cruise control with 105,000 miles. I negotiated down to $7600. After taxes and fees and everything, final cost was $8223.
  10. Moving Right Along
    690
    541
    A traction battery, also called a drive battery or HV (high voltage) battery, is half of what makes the car work. The Prius is a hybrid car that runs on a combination of engine and battery power. The traction battery, like any other part, can wear out. Also like the engine, it is very expensive to replace. However, it is designed to last the life of the vehicle and Toyota initially tested them to 180,000 miles. That means you probably won't have to worry about a battery going bad. Somewhere between 3-15% of people with a Prius of model year 2001-2007 have had one fail, and less than 1% of people with a 2008-2017 model year Prius have had a battery fail.
    A second generation Prius is one of model year 2004-2009. The generation of the car tells you how the car looks and what the general specifications are. To check battery health in a 2nd gen Prius, go to the Energy screen on the multifunction display and look at the bars on the battery icon. It should be between 5-7 bars, and should not go more than 2 bars higher or lower on a test drive. If the indicator bounces between 1 or 2 bars and 7 or 8 bars, then the battery is going bad and you should look at a different car.
    RCO likes this.
  11. jbirdawg
    53
    Atlanta, GA
    OK. I thought the "traction battery" may have been a different battery that that was put. I understand the basics of the power design. Thanks so much for that battery read out tip! What about the comprehensive maintenance?
  12. bisco
    49,514
    moi?:cool:
    Tideland Prius likes this.
  13. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    As the owner of a 2006 that just experienced a traction battery failure, I'd say that the 2009 would give you about 3 more years battery life than a 2006. A replacement traction battery costs $4500 barefoot at the dealer, $2000 if you are an expert shopper.
    RCO and bisco like this.
  14. bisco
    49,514
    aha! vindicated.:p
    RCO and Tideland Prius like this.
  15. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    ...you might find reading all you can about grid charging to be enlightening, and there are many threads hereabouts discussing the advantages and disadvantages of investing in a maintenance charging system! (see also Hybrid Automotive) Good luck! ...and Welcome to PriusChat! :)
    RCO, Raytheeagle and bisco like this.
  16. jbirdawg
    53
    Atlanta, GA
    Sorry to hear that! How many miles?
  17. jbirdawg
    53
    Atlanta, GA
    Thanks, Wil!
  18. jbirdawg
    53
    Atlanta, GA
    For virtually the same price, would you guys prefer a 2010 w new power plant and cargo space w 110K mi over a 2009 w 71K mi?
  19. bisco
    49,514
    i think i'd go with the '09. how new is the pp, and what is cargo space?
  20. jbirdawg
    53
    Atlanta, GA
    2010 engine 1.8L vs 1.5L, Cargo Room 21.6 cu. ft. to 14.4 cu. ft.
    Total Horsepower 134 hp to 110 hp 51/48 mpg 48/45 mpg.
    #20 jbirdawg, May 5, 2017
