Is there such a thing as a Prius being too old?
Discussion in 'Newbie Forum' started by Stephen Bish, Dec 27, 2016.
  1. Stephen Bish
    Stephen Bish New Member
    ADELAIDE
    2002 Prius
    I have a series one 2002 Prius which I bought 2cnd hand 10 years ago. It was an ex Govt (Environment Protection Dept) car when I bought it with 56k on the clock. It has been a fantastically reliable car for 10 years. It had full log book service till 190K and was due for the 200K when I lost my job 4 years ago. I could not afford the full service and ended up with just a basic service. Unfortunately it has had Zero servicing since, apart from the occasional engine oil level check and top up. On Boxing day morning I was greeted by a Christmas tree of warning lights, including the "triangle of death".
    It took me quite some time to discover what the 'Inverter coolant reservoir' was. It had a tiny bit of what looked like transmission fluid or power steering fluid in the bottom. About an inch below the "add" mark.
    Yes.... I know, I know... and all very sad.
    First point is that I have not driven it since. I have started it and turned it off pretty quick when I heard a suspect noise. Actually thought it might have been a timing belt, but no.
    I have looked through a lot of posts on this forum and watched a lot of videos re Inverter coolant and coolant pump. I eventually topped the reservoir up with demineralised water from the local servo but the pump does not seem to be working. Well there was a little movement and I could feel the vibration. The other thing is the liquid looks very thick. Sort of like Auto trans fluid, which is what I first thought it was. When I squeeze the hose leading back into the reservoir I get very thick fluid coming back into the reservoir.
    I have rung the local Toyota service dept, which only opened this morning after Christmas and need to ring them back when they quieten down. My Partner's Son in law's friend is a mechanic at another Toyota dealers and his advice was that it needs to go on their computer to check the error messages. Also that it is folly to try to bleed the inverter fluid yourself as you will never get rid of air bubbles, which is the main cause of inverter failure.
    My 2 questions are:
    1) How safe is it to drive the car to the dealers as is?... about 10km.
    and
    2)At what point would I be best advised not to throw good money after bad?
    The car has an agreed value of about $5000 on insurance and I would guess it's going to cost about $1500 for Inverter pump replacement and full service. That in itself would be acceptable if it meant the car would continue to give more trouble free miles for a long time but I fear it may just be the tip of the iceberg.
    I would greatly appreciate hearing from any one with an older Prius with high milage. Especially anyone doing basic maintenance themselves. I am unemployed and still 18 months off the age pension. I actually use the car as a work horse, delivering junk mail etc. It's far from the shiny new(ish) vehicle it once was.
    52,391
    welcome!:) i suspect there is such a thing as being too old. i know that i fall into that category, but i'll let gen 1 prius owners offer better advice. all the best!(y)
    RCO and Prodigyplace like this.
  3. Prodigyplace
    12,678
    11,830
    Central Virginia
    Welcome!
    You can find some Gen 1 Prius information at Generation 1 Prius Discussion | PriusChat
    I know @bwilson4web and other Gen 1 & former Gen 1 users will be happy to assist. I understand there are quite a few Gen Prius cars still around in active use.
    Personally, I am just getting acquainted with my Prius but I know there is a wealth of information here.
  4. Kenny94945
    Kenny94945 Active Member
    858
    433
    Sausalito
    2016 Prius v wagon
    If I am reading this right.....15 yr old car, with 200K mileage 4 year ago, and minimal service over the last four years.
    Not so sure if you are saying the car has an insurance value of $5K that will be paid out to you if you do not repair or if that $5K is a trade in value.
    At that age, I think you are looking at battery packs based on other posts in this forum.
    I believe those batteries are $2K to $4K at a dealer.
    Then your current repair of $1.5K.
    Brakes, tires, miscellaneous, unknowns.
    It is your call, yet I think you have one "old" "depreciated" "used up" car at that age and mileage and I would personally look to a replacement.
    I'd look over some replacements to see what is available, at the very least ,to aid in your decision.
    Maybe a search on this forum might show some trends of 300K Prius possibilities and repairs to attain that mileage.
    Good luck in your decisions.
    RCO likes this.
  5. Stephen Bish
    ADELAIDE
    2002 Prius
    Update........
    Gave up waiting for the local dealer to get back to me so rang the other mentioned dealer across town. Ended up with a pretty good arrangement which is a bit "best of both worlds". I have the car booked in next Tues afternoon and the mentioned family friend is going to do an inspection and report with his recommendations and will be doing any work I choose to go ahead with. May also be able to work out some sort of maintenance plan if I am to keep the car on the road, whereby I do some basic stuff like oil changes etc and let him look after the more complex stuff. I have basically done all my own maintenance for years on past cars but always felt this car to be too complicated. I do minimal driving these days, less than the 45k (kilometres not miles) in 4 years would suggest. I have been thinking of living without a car for some time as I have a good bus service outside my door which is free to use while the car costs me $25/week in registration and insurance alone. One option would be to simply put it off the road for a while with the option of putting it back in the future.
    A lot depends on the outcome next tues but anything I can learn about stretching the life of the car out at manageable costs in the mean time would help enormously with any resulting decision. My biggest concern is throwing good money after bad and any talk of thousands of dollars to replace batteries is just the type of thing I'm talking about. Do these cars still function with dead and/or dying batteries? or do they just spit the dummy and shut down?
    I will have a good read in the series one forum and I am most interested in just how much I can get away with doing myself to just keep the car on the road in a safe and usable manner.
    OH and Kenny, the reason I mention the "insured value" is just to give some idea of local value, which would of course be the estimated value of the car in good working condition as a write off value. Of course that would then be less excess. That value reduces each year as the policy renews.
    Thanks for all the advice and wish me luck next Tues, not just with the outcome of the checkup but with actually driving the car there in the first place. The more I think about it the more I think the problem with the Inverter coolant pump may be more a result of failed coolant rather than a failed pump. It may make sense to change the pump anyway though. I will be happy to just go with what Jason recommends. Nice to take a car to a dealer and actually feel you can trust what they are going to say.
    Prodigyplace likes this.
  6. bisco
    52,391
    all the best! love seeing the classics still on the road.(y)
  7. sttkailua
    sttkailua Active Member
    190
    151
    Hawaii
    Hi Stephen,
    Welcome to PC.
    Answer to your title: yes.
    I am in the camp as seeing a car as a consumable item.
    A tool to get you from point A to B safely, and making the trip enjoyable!
    At about 5 years, 100k, I start looking to upgrade.
    You have had a good run driving your Gen 1.
    It is at a point where upkeep, and maintenance cost increase, as
    paint, plastic, fabric parts start to crack and fade and fray.
    If your EV vehicle isn't up to 'Jay Leno' collector car condition, it may be time to let it go, put your money into a Gen. 3 or 4.
    You would be pleased at how much comfort and safety upgrades have improved since 2002.
    Good luck!
    stt
    RCO likes this.
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Stephen, I've been there twice. Chances are if you start to repair the car you will end up having to restore the car. Unless car restoration is a hobby you want to explore from my experience it is time to cut your losses and let it go. Very few cars are worth the price of restoration.
    Problem #1 gets fixed for $n. Then Problem #2 appears. Since I just spent $n I'll have to spend $x now to get my money's worth out of the first repair. Then just around the corner Problem #3 pops up...
    A$5000=US$3621
    My guess is the car needs or will need:
    belts & hoses
    batteries (12v & HV)
    tires
    an inverter coolant pump (not sure what happens when coolant turns to goo)
    Has the coolant for the engine turned to goo?
    RCO likes this.
  9. Stephen Bish
    ADELAIDE
    2002 Prius
    Update
    Thank you all for your replys and there are a couple more I had missed. I am very lucky to have a family friend who is a mechanic at a Toyota dealership. I took the car in for a check and the main problem is the HV batteries. At least according to the scan. Looking like I am heading to life without a car as a replacement that is not just a whole heap of "someone else problems" is out of my price range. Situation is at present the car is 'drivable' with the warning lights on but dying. End result being batteries giving up completely and car refusing to start or function. At least that's my understanding atm. I have joined the local RAA for towing insurance on a monthly basis and I'll see what happens. There are a number of things I am not clear on but it seems to me the HV batteries from a Series One are not interchangeable with later models. I had half thought of buying the new one (as long as it comes with a decent warranty) thinking well if worst comes to worst I could sell it on. That got me to thinking maybe I could find one from a wreckers. Big question is what fits what though.
    According to Jason ( the mentioned mechanic) it would cost me about $3200 for the battery including fitting ( which is about $400 labor and having watched some youtube videos nothing I would attempt myself) He also suggested getting a basic service in the first instance as that would give me a report on any potential problems. ( probably about $250)
    A full service, including all fluids, spark plugs etc etc would probably be about $1000.
    Now here's the thing. OK. I could probably offload the one I have to a wreaking yard for next to nothing and spent that money on something else but would I just end up with someone else problems?
    Btw the coolant pump does appear to be working, though not that energetically once the car warms up. For an extra few hundred $ it would probably be wise to replace it though if I get all the fluids changed.
    I guess the bottom line is that if the HV battery for a series one fits a series one only it would be absolute madness to buy a new one.
  10. Moving Right Along
    Moving Right Along Senior Member
    732
    588
    Depending on how much money you have and how much you need a car, there are still some decent options in the $2000 range for either older high-mileage (200k) reliable models or older middle-mileage (100k) average models.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You do realise the OP is in Adelaide, Australia?
  12. Moving Right Along
    732
    588
    Nope, can't say I noticed that :oops: Oops!
    RCO likes this.
  13. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    I tend to think that for somebody who doesn't drive much a relatively newer but higher-mileage used car may make sense, one that has more years than miles left in it. Also, avoid "complicated" vehicles (hybrids, eco-boost, etc) since if you're not driving a lot you won't realize the benefit of all that complication.
    I would consider a pure electric car as simple, but even though early models are depreciating like a rock I don't think they've quite reached the level of a conventional economy car. There's also the question of whether low annual mileage is achieved driving a little every day, or by infrequent longer trips that would exceed EV range.
    RCO likes this.
