Is they key waterproof?
Discussion in 'Gen 3 Prius Main Forum' started by EvanB, Aug 8, 2014.
  1. EvanB
    EvanB Junior Member
    39
    Phoenix, Arizona
    2014 Prius Plug-in
    And if so to what degree.
    If I get soaking wet at the gym from spin class, is the key safe?
    If some one pushes me in to the pool, is the key safe?
    If I go to the beach and put the key in a zipper pocket when I go in the water, is they key safe?
    If I go 20,000 leagues under the sea and a monster attacks me, is the key safe?
  2. mrbigh
    3,686
    699
    Long Island, NY
    get an umbrella handy or put it inside of a condom.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Spin Class requires "weatherproof" not "waterproof" generally and the key should be fine. Moisture on the outside while not great, shouldn't make its way into the case by light pressure by wet pants.
    In the pool, it is not safe. It is fully submerged. The pressure will push the air out and water in.
    At the beach, not safe.
    Under the sea, not safe. But you could use the slide out mechanical key to help fend off the monster.
    Data Daedalus likes this.
  4. situationalawareness
    83
    43
    San Tan Valley, AZ
    Just treat it as you would a cell phone, and you'd be good.
  5. gliderman
    gliderman Active Member
    751
    225
    What did Toyota say when you asked them?
  6. bisco
    52,360
    how you gonna get li'l keys?:(
  7. orenji
    orenji Senior Member
    5,887
    3,488
    I have washed mine in the washer. Still works fine!
  8. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    If the key goes through the washer or swimming in salt water, your best bet is to rinse it in distilled water. Open up the case like you would to change the battery, remove the circuit board, and rinse everything in distilled water. There are circuit board cleaning sprays available at Radio Shack and the like, which might work better. The electronics industry has cut down on their use of toxic chemicals by substituting ultra clean water for many chemical cleaners. You might also replace the battery while the fob is open.
    This all assumes Gen3+ keyfobs. Gen2 are sealed with glue and are much more difficult to open. But the circuit board is just as vulnerable to salt water. The Gen2 keyfob has a fully sealed transponder in it, which should work even if the circuit board is toast. So the "key in the dash" function would not be impacted.
  9. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Chlorine and salt water are two of the worst things you could submerge your key fob in.
    SCH-I535
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The GII FOB is NOT "sealed". It has a "water repellant seal" but that's it. The GII FOB will still fill with water when immersed.
    If you can foresee the FOB being immersed in water and have time, remove the battery. If you didn't have time to do so remove the battery ASAP. The battery will drive electrolysis, which will destroy the FOB.
    You should NEVER -plan- to immerse the FOB in water except when cleaning it - and then only without the battery installed. -I- wouldn't even use a "waterproof carrying device". It's just a chance you usually don't need to take. If you're canoeing fine. Carry the -key- (remove from FOB) in your swimming trunks yes, leave the FOB in a metal case in the car. The metal case is there to prevent the car from sensing the FOB inside and preventing you from locking the doors. Use the key to open the drivers door to retrieve the FOB. Do remember that, if thieves find the FOB in the car the car is theirs. Key or not.
    The FOB is designed to "repel" water but not to be immersed in it.
    WilDavis likes this.
  11. qdllc
    qdllc Senior Member
    1,377
    400
    I'd say the fob would survive a quick dip underwater, but it's not designed for depth or duration under water.
    Sweat, water spills, drops in the sink...no problem.
  12. Lee Mooring
    Lee Mooring New Member
    Chester, SC
    My battery did not survive a trip through the wash. Remote worked after drying and replacing the battery.
  13. Beachnut
    Beachnut Member
    185
    43
    Yea but.... I want to know if the Sea monster at 20,000 leagues under the sea, ate the poor baby keys or not?:ROFLMAO:
    Good thread...(y)
  14. Okinawa
    Okinawa Senior Member
    1,333
    320
    No, it is not waterproof.
  15. cipsaz187
    cipsaz187 Member
    150
    42
    I've been swimming in atlantic with the Gen II fob for like 30 min until I realized I had a fob in my pocket. At the end of the beach day it worked. Do not test its limits.
    orenji likes this.
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Regardless of individual testaments to the survival of the fob in various water logged situations, my advice is to treat the fob as if it is entirely NOT water proof.
    It is an expensive piece of equipment and I simply think it best to default to the wisdom of keeping it as dry and secure as possible.
    If you are accidently forced to test it's survival capabilities? Then hope for the best. But if the question is how to treat the fob?
    I suggest treating it like ammunition. Keep it dry, safe and secure.
    If the ship over turns? Listen to Gene Hackman and climb up the Christmas tree and head for the propeller area. But keep the fob dry.
    trentofdestiny likes this.
  17. ETC(SS)
    7,335
    Lol.
    Nothing is water-proof! ;)
    However......
    Your fob should be Maytag/pool-side/toilet "resistant".
    ...er....as long as you don't flush the toilet. :eek:
    Try to keep it away from salt-water, and don't worry about 20,000 leagues thing.
    Verne's book title is misunderstood by many to mean a submarine operating at 20,000 leagues of keel depth, which on earth is not possible.
    20,000 Leagues Under The Sea refers instead to traveling that distance (69,000 miles) while under water, which is not only possible, but I've done it myself----just not all at once.
    If your Keyfob is inside the sub?
    It'll be OK.
    Even if you wash it in the ships' laundry while at test depth.....
    However (comma!) the FOB won't do you much good underwater, under-way.
    Life is like that sometimes.....
    Good Luck!!!
