Is this a bad idea? (Used OEM speed sensor)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LazuliNyx, Jul 16, 2025 at 10:11 AM.
  1. LazuliNyx
    LazuliNyx Junior Member
    46
    30
    Georgia, USA
    My ABS light came on, and after scanning I found out it's a C0205, the front left wheel speed sensor circuit failed. I looked at turns out one of the mounting clips for the speed sensor's cable broke and it contacted the tire, leading to a short. I patched it up with some wire for now, so I at least have ABS and regenerative braking back. A new speed sensor is $225 from the dealer, $150 after shipping on Amayama. Would it make sense just to get a used OEM one for $50? I'm guessing it's not a part likely to fail unless something happens mechanically? If this isn't a bad idea, where would you recommend getting this from? Thanks!.
  2. Tombukt2
    Tombukt2 Senior Member
    12,231
    2,158
    Durham NC
    You should be getting used ones for like free
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,616
    5,914
    Texas Hill Country
    If you do a watertight repair you could use what you have otherwise a used oem assembly (89543-47030) would be my choice.
    Brian1954 likes this.
