IS THIS A DEALER HYBRID BATTERY CHARGER?
Discussion in 'Gen 3 Prius Technical Discussion' started by Dacus_Malus, Jul 5, 2019.
  1. Dacus_Malus
    Dacus_Malus Junior Member
    26
    When I bought my car (2 years ago) I found this charger in the trunk.
    What is it? And what did it do?
    I have a 2006 red Prius executive, bought at 220 000 km and now it have 280 000 km.
    And I just start having HV battery problems. This charger can help me?
    Thanks.
      File size:
      158.3 KB
      File size:
      189.4 KB
      File size:
      147.9 KB
  2. PriusCamper
    PriusCamper Senior Member
    12,303
    4,999
    Pacific Northwest, USA
    Hello... I've never seen this. Are you in SE Asia?
    We might be able to explain what this is about if you tell us what country you're located in?
  3. tvpierce
    tvpierce Senior Member
    951
    882
    Maine
    2013 Prius v wagon
    I don’t read Chinese. The only thing I can read on that label is 12V and I can’t think of a reason a traction battery charger would use 12V on either the input or output side.
    Does that connect to a wire harness on the car. Id like to see a pic of that.
    Do you read Chinese?
  4. fuzzy1
    10,337
    No, but that wouldn't help anyways. That text isn't written in Chinese.
    #4 fuzzy1, Jul 5, 2019
    VFerdman likes this.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,396
    2,375
    Taylors, SC
    Right, it's Japanese. I read neither.
  6. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    FWIW: Pretty sure that is Japanese (katakana style characters).
  7. bisco
    51,492
    why are we in the gen 3 forum?
  8. PriusCamper
    12,303
    4,999
    It's karmic pay back for all the times Gen3 people messed up the Gen2 forum! :)
    RMB likes this.
  9. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    I'[m fairly certain it says (1) Connect it properly to something with 12 volts, (2) Press the Start button, (3) Look for the Charge LED, and hope the Fault LED stays off. The box, below all that, contains some cautions to be observed, maybe in relation to hydrogen from charging the battery; no flames, proper ventilation, etc. I think we all want to know exactly what this box is supposed to do. The orange connector implies high voltage like the traction battery or inverter and a white plug is normally for communications, if I am not mistaken.
    Raytheeagle and bisco like this.
  10. PriusCamper
    12,303
    4,999
    Thanks.... Hope the person posting this can bench test it and see what the output is. Hoping it's output is 250w at 1/4amp... But I suspect it's just a 12v trickle charger and it's not as great as we want it to be.
    I've always said that CARB states should of learned more about battery packs before simply extending the warranty to 150K miles. They could of realized that instead of warranty, requiring Toyota to include a charger & reconditioning system in every car sold would of kept the battery packs healthier for far longer than the warranty.
  11. bisco
    51,492
    it's political, not technical
  12. PriusCamper
    12,303
    4,999
    Yea I for sure "hope your fault LED stays off."
  13. Dacus_Malus
    26
    I am from Romania. (central-est Europe)
    I open this thread here, but I open first a similar thread on Gen.2 section.....someone there sugest me to open here, because is more likely to find answers.
    I don't have a " trial bench"...but I will try to "open" it maybe the inside will provide much info.
    PriusCamper likes this.
  14. tvpierce
    951
    882
    Maine
    2013 Prius v wagon
    All you need is a multimeter that reads AC & DC volts.
    Is there a corresponding wire harness on the vehicle with that connects to it?
  15. Dacus_Malus
    26
    @tvpierce: I don't know. Next time when I will have to remove the hv battery , I will check.
    Meantime, the dimensions: 20 cm x 10 cm x 7 cm.
    Weight = around 1,5 kg.
    I found this code on a side:
  16. Dacus_Malus
    26
    And opened:
  17. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,513
    Bay Area, California
    2019 Prius Prime
  18. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Because the vending machines are stocked better.
    bisco and Ed Beaty like this.
  19. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    Dacus_Malus likes this.
  20. Dacus_Malus
    26
    Thanks, you found it!
    So is a charger who is normaly installed in the car.....
    I will keep it, becasue my wife has a 2001 Prius, and maybe i will need it as a spare part.
    Raytheeagle likes this.
