Is this a fair price for a new catalytic converter installed?
Discussion in 'Gen 2 Prius Main Forum' started by mckenzmm, Apr 15, 2020.
  1. mckenzmm
    mckenzmm New Member
    Wisconsin
    I just got a quote for a catalytic converter replacement on my 2006 Prius with 190k. Hoping you can tell me if this is a good deal or not? Thanks for any input!
    Catalytic Converter Assembly 16337 $598.65
    Gasket 31379 $26.55
    Spring and Bolt Kit 36454 $22.13
    Exhaust Clamp $1.88
    Shop Supplies $23.97
    Labor $149.85
    Total with tax $868.30
    $75 off coupon $793.30
    I know the parts are marked up quite a bit. Are they still getting a lot of money when they scrap the original catalytic converter on these? Thanks!
    Data Daedalus likes this.
  2. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Welcome to PriusChat!!
    Are you sure the catalytic needs replacement?
    If it was stolen, do you also have a plan to protect the replacement?
    The price seems a bit high, considering that Walker goes for around $300 elsewhere. And you can find other replacements, though they might not be at the same level of the Walker product for around $100. I would continue to shop around, using the walker part# to compare installed pricing at the various shops.
    What is the warranty for the installed product, and will they stand behind their job if the vehicle doesn't pass emissions?
    I've heard used gen2 cats can be worth 500-800 each. There are members offering to pay over 300, so there must be additional upside $$$.
    Data Daedalus and mckenzmm like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    I just googled "Catalytic Converter Assembly 16337." This was right at the top of the page.
    Of course, it could be worse. Toyota sells their cats for about $1,400-$2,149. :eek:
    #3 jerrymildred, Apr 16, 2020
    kenoarto and mckenzmm like this.
  4. ChapmanF
    15,105
    But isn't the Toyota one the whole front pipe, and stainless?
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,100
    5,812
    Columbia, SC
    If they are replacing a catalytic converter that is still in the car, I would insist the old assembly be returned to me. The pair of cats go for about $600 on ebay.
    If it's an exhaust shop, all they're going to do is cut the pipe right after the second cat and either splice in the new one or use a hydraulic expander to expand the end of the new one, slip it on, clamp it and bolt it up. 30 minute job for an exhaust shop if it's a rookie.
    You can always order the replacement cat yourself and have an exhaust shop install it.
  6. mckenzmm
    mckenzmm New Member
    Wisconsin
    Thanks! Toyota Dealership, private mechanic shop and another Prius mechanic have all told me it is the cat. Haven't given too much thought to it being stolen. I have a pretty secure indoor parking spot.
    Warranty is three years, 36k miles. Not sure about emissions. I'll have to look into that.
  7. jerrymildred
    11,491
    14,100
    Tampa, FL
    Looks like it from the drawings I saw.
  8. Rmay635703
    Rmay635703 Senior Member
    2,580
    1,601
    Somewhere in Wisconsin
    2013 Chevy Volt
    A blowtorch and shop air will fix most any plugged CAT.
    kenoarto likes this.
  9. TMR-JWAP
    6,100
    5,812
    Columbia, SC
    Does the car run well? If the only concern is that you have a P0420 code, that's not really a big deal unless you want it to be. If your state has strict inspections and the car won't pass due to code, that's one thing. If it's just the code, the car will work fine and it's really an unnecessary expense to have it replaced. My white 2005 had 290k + miles and it ran at 50+ mpg for over a year with that code before it got run off the road and totaled. My son's current 2005 has had the code since we bought it about 2 years ago and runs like a champ. He's around 200k+ miles now.
    And I was wrong about ebay, they're currently fetching $900+ for the set.
    mckenzmm and jerrymildred like this.
  10. jerrymildred
    11,491
    14,100
    Tampa, FL
    If it was stolen, you would have to be stone deaf to not hear that open pipe when the engine starts up. ;)
  11. TMR-JWAP
    6,100
    5,812
    Columbia, SC
    I think you're right about this, plus, nowhere in that quote is there an oxygen sensor. If the cats were stolen, they usually cut the wires for the sensor also, doubt thieves are going to waste time unscrewing it from the pipe
    Data Daedalus and jerrymildred like this.
  12. jerrymildred
    11,491
    14,100
    Tampa, FL
    Yup. Cat's way in front of the muffler.
  13. mckenzmm
    mckenzmm New Member
    Wisconsin
    Yes, the car runs well. Getting 50mpg at the moment. I might wait until my next emissions test in October to get it repaired.
  14. TMR-JWAP
    6,100
    5,812
    Columbia, SC
    If you happen to be passing through Columbia before that, let me know. I'll order a complete replacement for it and swap it for you at no cost if you let me keep the OEM. Would take less than an hour.
    mckenzmm and Data Daedalus like this.
  15. mckenzmm
    mckenzmm New Member
    Wisconsin
    Update. This week the check engine light has gone away on its own and my mpg went from 50 to 54.
    jerrymildred likes this.
  16. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    I buy prius Catalytic converters, right now I'm paying $750 for the 2004-2009 sets which read gd3/ea6.
    My cell is 6312915509
    mckenzmm likes this.
  17. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Thats some markup, I recommend the OP just order it themselves and bring it somewhere cheaper. The cat most likely comes with new springs and a gasket (which the shop is charging extra for) and honestly this job is about a half hour of labor for a mechanic on a lift. I can do it in 10 minutes.
  18. mckenzmm
    mckenzmm New Member
    Wisconsin
    Are you near Wisconsin? I'd bring it to you! ;)
  19. George W
    George W Active Member
    909
    510
    San Antonio
    The Walker says it requires a matched resonator assembly. How does that fit under a Gen 2 Prius?
