Is this a normal engine sound?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by nervousnoob, Dec 7, 2023.
  1. nervousnoob
    nervousnoob New Member
    Palo alto
    2015 Prius Plug-in
    Prius noob here. Just got a 2015 pip. Want get a second opinion if this sound is normal? The rpm seems to rev up after starting the car. And has some vibrations as well, which go away once the rpm comes down.
  2. Tideland Prius
    16,678
    From what I can remember, this sounds ok. Maybe a touch rougher than I remember. But it does run richer when the engine is cold to heat up the catalytic converter.
    nervousnoob likes this.
    52,841
    welcome!
    sounds right to me, it's a noisy little engine.
    how many miles on her?
  4. nervousnoob
    Palo alto
    2015 Prius Plug-in
    75k
  5. bisco
    52,841
    i think you're good
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,087
    6,950
    Texas Hill Country
    It is noisier when it is charging the battery and is quieter after it unloads the motor generator just before shutting down.
    In the morning with a full hv battery it will be quieter as it just warms the engine. In both cases it partially charges or partially warms the engine.
    No one ever accused these engines of being quiet.
  7. nervousnoob
    Palo alto
    2015 Prius Plug-in
    Thank you all!
