Is this a normal sound? Drivetrain.
Discussion in 'Gen 3 Prius Technical Discussion' started by mypriuscious, Jul 16, 2020.
  1. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    I've been getting a clunk sound when I stop and start moving the car. It was a bit difficult to record that sound so I jacked up the car and rotated the wheel back and forth. Trying to chase down where this sound might be coming from. These are google drive links to the videos I made of driver and passenger.
    49,415
    normal for a 10 year old car at what mileage?
  3. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    370k
    49,415
    just a guess, maybe the drive shafts?
  5. mjoo
    mjoo Senior Member
    1,116
    1,312
    Michigan
    Flywheel?
    Kasra likes this.
  6. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    That is what I also thought, but I wanted to ask here for a second opinion. Because if it isn't that, it's the transmission I suppose? But a used one of those with decent miles is almost as cheap as two non oem half shafts.
  7. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    Do these cars even have a flywheel?
  8. mjoo
    mjoo Senior Member
    1,116
    1,312
    Michigan
    Like, totally!
    Search is our friend.
    It's the damper assy that can break then vibrate. Has been posted about a few times at least.
    https://priuschat.com/index.php?posts/3005835
    mypriuscious and Raytheeagle like this.
  9. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    Yeah, you're right. I just assumed because the car was started by the transmission it didn't have one.
    mjoo likes this.
  10. ASRDogman
    ASRDogman Senior Member
    6,077
    3,270
    You would thing since there is no pressure on the crankshaft pulley it would not go back.
    But I guess it would just deteriorate from the heat/cold cycles....
  11. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    Sounds to me like it’s just the parking pawl inside the gear case. Normal if the car is in park.
  12. ASRDogman
    6,077
    3,270
    I need a better proof reader!
    thing-think
    back-bad
