Is this a real problem?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by doogster, Oct 4, 2013.
  1. doogster
    doogster Junior Member
    65
    My 2006 Prius has 151,000 miles on it. I've only owned it since June 2012 when it had 118,000 miles on it. I've never had a single problem - yet. I'm going to try and describe what happened to me on the way to work this morning - because something very strange happened.
    I had driven this morning about halfway to work - about 5 miles or so. I was on a highway when the light in front of me turned yellow - at first I thought I could make it, then realized I should stop - so I did.
    When the light turned green, I gave it gas - but something was wrong. The yellow light on the dash started flashing (I think it's a traction light or something like that) and the car wasn't hardly moving. I let up on the gas and tried again... but it continued to light up and the car almost felt like it was either bogging down (hard to describe) or the wheels were slipping??? Not sure exactly.
    After about 20 seconds... the light went off and the car was fine. I drove the rest of the way to work with no problem. I stopped at several other lights but the symptom did not return.
    I don't THINK there was anything on the road that was causing the wheels to slip because I stopped rather sharply at the light and didn't skid or anything... but I really don't know... it was dark.
    Any thoughts?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Lets assume you stopped so hard you used the real friction brakes rather than the regenerative power of the electric motors.
    It may have been some time since they had the rust worn off, this could easy be a one time thing or it may be waiting to happen again.
    One way to test is to put the car in N (prevents regeneration) and brake pretty hard as you did that night. If the problem reoccurs, get the brakes fixed pronto, you need to be able to stop.
  3. Patrick Wong
    18,200
    6,474
    Was the ground wet at the area where you had this problem?
    Check your car's tire tread depth, especially the front tires. My guess is that the tires may need to be replaced. If the depth is OK (6/32" or better) check the tire inflation pressure.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Doesn't sound like a brake issue to me.
    Sounds like the traction control was kicking in for some unknown reason.
    It could be the tires, or perhaps the environmental conditions on the road that morning.
  5. doogster
    65
    Well... this morning was dry and 64 degrees... and the tires have only 3,000 miles on them. I just checked the pressure the other day... so, unfortunately, its none of those things.
  6. The Electric Me
    9,083
    5,798
    Well, at this point it's only a single incident that evidently only lasted about 20 seconds.
    That's not to say you don't have a problem developing, but you might have to wait until it get's worse to track it down.
    Have the symptoms returned? Is the vehicle doing it still or again?
    Your biggest clue, might be whatever warning light was flashing. Look in your owners manual and verify.
    Because "assuming" it was your traction control light flashing...then all we know is that your traction control was evidently activated.
    Unfortunately, if it's a "real" problem it will return. If it was the system reacting to a unseen slick spot, or rust on the brakes...it probably won't.
  7. doogster
    65
    symptom has not returned... I have driven 200 miles now since it happened....
  8. fuzzy1
    10,172
    Were both front wheels starting on good dry pavement? Or could one of the wheels been on slick (from water, oil, or simply well polished) metal (e.g. access hole or construction cover) or paint (crosswalk or road marking)?
