Is this a seam or a crack?
Discussion in 'Gen 2 Prius Main Forum' started by mehrenst, Jun 27, 2005.
  1. mehrenst
    mehrenst Member
    439
    San Jose, CA
    When I was driving into the garage today I noticed what appeared to be a crack in the smoked instrument cluster glass/plastic. I could only see it from the drivers seat and the sun/light has to be in just the right position. However, you can feel it with your finger/fingernail.
    I've attached a stock Prius pic with the approximate location indicated by the arrow. I will attempt to get an actual shot tomorrow with my digital camera and post it as a supplement.
    My questions are:
    #1. Has anyone else seen this on their car?
    #2. Has anyone else asked their dealer about it?
    #3. Is it a crack or is it a seam in the panel?
    I hate the thought of having to have this replaced :cussing: because it is likely that the dealer will not get things back together with the same factory fit/finish. (I have less than 500 miles on the car.)
    Thanks.
  2. kkister1492
    kkister1492 New Member
    355
    Fremont, CA
    I've got it, too, so have to assume it's a seam.
  3. removeum
    removeum Member
    407
    El Paso, TX
    8) mehrenst,
    It is a seam and it is on all 04 and 05 Prius.
  4. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    #1. Yes
    #2. Yes. (Not me)
    #3. A seam.
    It' normal. Don't worry.
  5. mehrenst
    mehrenst Member
    439
    San Jose, CA
    Thanks guys. I feel better (almost) :|
  6. chrism07924
    chrism07924 New Member
    79
    Bernardsville NJ
    Had the same question a while back. I never noticed it until the plastic was replaced for some minor and unrelated scratches.
  7. Rest
    Rest Active Member
    1,210
    CA
    A picture of what is being talked about might be nice. A crack is not perfectly straight but that lens is in two parts.
  8. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(removeum @ Jun 27 2005, 09:55 PM) [snapback]102199[/snapback]</div>
    It's there on my '06; the dash underneath the smoked plastic is also a bit wavy towards the passenger side.
  9. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Rest @ Nov 1 2006, 12:32 AM) [snapback]341772[/snapback]</div>
    Solved five months ago... it is the seam between the two dash lens pieces.
