Is This All I Should Expect?
Discussion in 'Gen 2 Prius Fuel Economy' started by Corwin, Dec 14, 2016.
  1. Corwin
    Corwin Junior Member
    Avon, OH
    I purchased my 2007 about 6 months ago and have been less than impressed by the fuel economy. Admittedly, my commute isn't necessarily hybrid-friendly (essentially all highway), but I still expected to far exceed the MPG I was getting in my Corolla. As it turns out, it's roughly the same.
    I've read through many threads the past few months and have followed all of the suggestions that are commonly recommended, including keeping tires inflated to max pressure, driving at the speed limit, gliding when possible and using the electric motor when I can, which is mostly through the neighborhood on my way home from work.
    Over the summer I was getting 41-42 MPG and now I'm getting 35-36 due to colder temps - I'm located just outside of Cleveland. My commute is roughly 26 miles, 15 miles of which I set cruise control at 70 mph and the remainder set at 55 mph (country road). Terrain is relatively flat throughout the commute.
    Should I be surprised by the results I'm seeing? I thought about installing a grill block for the winter season, but it seems I'm so far off the mark at this point that doing so wouldn't amount to much improvement in FE. I love the car, but never thought I'd have to try this hard to get these results.
    49,489
    don't use the electric motor, where did you read that?
    if you were only getting 40 mpg in good weather at 55 mph, there's something wrong with your car. but with 15 miles of 70 mph, that will hamper things. truth is, the hybrid system isn't that effective on the highway.
    let's start with tyres, are they LRR? oil level? 12v battery health? air filter?
    how many miles on her, has she hard all services performed? there are a couple that aren't in the book.
    saltdiscus likes this.
  3. Corwin
    Avon, OH
    Sorry, I'm not sure I understand your comment about the electric motor. While driving through the neighborhood I'm at speeds < 40mph, which means I'm able to use battery only - no ICE usage.
  4. Corwin
    Avon, OH
    The tires are Cooper CS5 Grand Touring, which I don't believe are LRR tires. Still, they came with the car and are in good shape, so I won't replace them until they need it. I haven't checked the oil level, though I assume it's where it needs to be, since the 100k service was done just a few weeks ago. I changed the 12V battery earlier this week after the old one died. I saw a bump in FE of about 2 MPG. The car has about 105k miles, so not high mileage relative to is age.
    Also, the previous owners were very good about servicing. I have all of the service records.
  5. bisco
    49,489
    maybe you need to service some oddball things like the throttle body and maf, pcv and intake manifold, injectors and etc. just guesswork, but something is causing your low mpg's, although you're not that low, so it might not be worth the effort.
  6. dolj
    dolj Senior Member
    7,655
    3,867
    Wellington, New Zealand
    That is fine as long as you are not trying to force the car to use the electric motor when it would otherwise want to use the ICE (internal combustion engine).
    Many people have this idea that they should run the car in electric to get the best MPG, but this is not the case. Due to energy conversion losses, it is more inefficient to force the use the energy stored in the battery. You are better off to allow the ICE to run in the 94+ to 49 MPG range. Allow the car to manage the battery to supplement the ICE. It is after all, a petrol vehicle with electric assist, not an electric vehicle (EV), albeit, a very clever implementation.
    But I'm with Bisco, you should be able to get 55-60 MPG in summer and 45-50 MPG in winter, so something is wrong with the car, or the driver.
    One other thing, how are you measuring your MPG? The the only reliable way is to record miles run and gallons used to calculate the MPG. Because of the variability of the fuel tank bladder, you then need to average the last three tanks (minimum) to get an accurate idea of the true MPG. Using the average on the consumption screen is very subjective. BTW, when was the last time you reset the average MPG counter?
    I disagree with Bisco also about highway driving, with the qualification that after 65 mph it gets increasingly difficult to maintain an average over 50 MPG. But under that speed, there is no reason you couldn't (shouldn't) get 94 - 67 mpg (on the instantaneous MPG meter) for extended periods (on generally flat terrain). Use the DWB (driving without brakes) technique to anticipate the road/traffic ahead and you will see great results on the highway.
    #6 dolj, Dec 14, 2016
    Data Daedalus and bisco like this.
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yes, you should be surprised at the fuel economy. I have a used 2005 using cheapo non LRR tires. I drive all freeway except for the distance from my house to the freeway and my work to the freeway. (<1 mile) I rarely drive local otherwise. I don't drive slowly. I'm on the left lane going up to 85 mpg going up and down inclines. My commute is not flat. I don't use cruise control. I don't glide. I don't force EV operation. In short, I drive my Prius like I would any other car. I'm getting 46 mpg after 1 year of usage. In my 2006 Corolla, I would get ~36 mpg.
    Data Daedalus and Corwin like this.
  8. Corwin
    Avon, OH
    @dolj - ok, makes sense what you're saying about the EV mode. I was essentially forcing the car to stay in EV mode, but will let the car do its thing from now on. In terms of measuring MPG, I'm using the screen on the MFD, which I reset after each fill up. I'm not certain about the tank size, since I'm too scared to run it past 1 fuel bar :)
    I'll try the DWB technique, but usually traffic is so light that I can set the cruise control at 70 and forget about it. Same with the portion of the commute that's at 55.
  9. Corwin
    Avon, OH
    I should mention that the car came equipped with a Thule bike roof rack, which I use to haul my mountain bike. I suppose I could remove it to see the impact it has, but I'm assuming it's not having a substantial impact. Thoughts?
  10. dolj
    dolj Senior Member
    7,655
    3,867
    Light traffic will work in your favour, but if you need to slow down, disengage the CC early on, like really early on.
    I think you'll be surprised the effect that will have. Seriously will change the Cd (co-efficient of drag) of the vehicle.
    Remove it and only reinstall when you need to use it. Or, take the hit.
    Mendel Leisk and Data Daedalus like this.
  11. mmmodem
    2,732
    1,703
    Bay Area, CA
    Only way to find out is to try it.
    I don't reset the MFD. It resets on its own when I fill up. I find it's always optimistic 1-2 mpg. I calculate 46 and it shows me 48. There's no need to run the tank empty. You can fill up at half if you like.
    Again, you don't have to try to get 45 mpg. If everything is working properly. That's what you get driving normally. When you try and hyper mile, you'll get 50 mpg and beyond. And if you do it incorrectly like forcing EV could also bring you below 45. As to why you're not at 45, I'll let the experts diagnose.
  12. dolj
    dolj Senior Member
    7,655
    3,867
    This is one of the problems when offering anecdotes in relation to a non-Gen II model.
    The facelift Gen II (2006-2009) only resets the tank milage on the consumption screen when you fill up.
    The first release Gen II (2004-2005) resets both the average MPG and the tank milage when you fill up.
  13. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    At 70mph, you should be at least in the low 50s mpg wise. The Prius is however very sensitive to changes to its aerodynamics. I had the front plastic under-panel fall off on one of my trips, and even though it only sticks down about an inch below the other panels it covers, my mpg was very low for the 500 mile trip I did. When I did the same trip in nearly the same conditions with it repaired I got 5mpg better. Anecdotal, but it's clear the panel is important for the car's aerodynamics.
    Therefore I'd say there's a good chance the bike rack could be causing a significant hit. Take it off and see if you get an improvement. A switch to low rolling resistance tires would also help.
    Other things that could cause it are brakes dragging, bad alignment, clogged air filter, etc.
  14. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    Holiday Hypermiling Seasons Greetings Corwin - As a Christmas gift to you, I have pulled a tweaked (by me) GEN II/2G version of some "Hybrid $mart" Driving tips from my personal "Hybrid Hypermiling - Hybrid EcoDriving - Ultra High MPG" web page for your consideration and edification.
    "HYBRID $MART" DRIVING CONTRIBUTIONS TO AVERAGE MPG
    Pseudo-Hypermiling/EcoDriving Pre-Operative Set-Ups:
    "Up-Pressuring" Tire Air Pressure [Plus: 3+/- MPG Gain going from 35F/33R to 44F/42R PSI running on the OEM Low Rolling Resistance (LRR) tires for 2G.
    • Replacing Conventional “Dino” Oil with 100% Full-Synthetic Oil [Plus: 1.5+/- MPG Gain going from 5w30 “Dino” to 100% Full-Synthetic 5w30 for 2G].
    • Engine/Drive-Train Break-In [Plus: 2+/- MPG Gain after 10,000+ miles].
    • EBH and Grille Louver Blocking Insulation Foam (Very Cold Climate Ops Only) [Plus: 3 to 8+/- MPG Gain].
    • Use of Federal and State mandated 90:10 E10 "10% Ethanol Added" Gasohol [Minus: 1 to 3+/- MPG Loss]
    Pseudo-Hypermiling/EcoDriving Operating-Driving Techniques:
    • Running HVAC From Fresh Air Vent Only Mode Through To Full-Time A/C AUTO Mode [Minus: 0 to 4-8+/- MPG Loss]
    • Employing Acceleration Technique of iMPG iMPH/2 When Accelerating From Dead Stop Then Seamlessly Transitioning To iMPG 1.1 To 1.2 Times iMPH As Travel/Cruise Target Speed Is Approached [Plus: 2+/- MPG Gain in Around-Town/Mixed City-Highway Driving].
    • Skillful Application of "Hybrid $mart" Freewheeling Coasting, Regenerative Coasting, and Regenerative Braking [Plus: 2+/- MPG Gain in Per-Full-Tank-Average MPG-FE for Around-Town/Mixed City-Highway Driving].
    • Consolidating Shopping Trips/≤ 2-Minute Errand Running [Plus: 0.5+/- MPG Gain in Per-Full-Tank-Average MPG-FE for Around-Town/Mixed City-Highway Driving].
    • Opportunistic Use of Advanced Fuel Conserving Warp-Stealth, Pulse & Glide, Dash & Coast and Super "Atkinson" Highway Mode [SAHM/SHM], Driving With Load (DWL) Techniques [Plus: 2+/- MPG Gain].
    • Driving GEN II 2G at 66 MPH Fuel Economy “Sweet Spot” ECC Cruise Set Speed, rather than driving 2G @ 70-75± MPH during Open-Road/Interstate travel that is 99.5% Freeway/Interstate [Plus: 3.5+/- MPG Gain For High-Speed Open-Road/Freeway/Interstate Driving].
    TOTAL POTENTIAL ADDED INCREMENTAL MPG CONTRIBUTIONS AVAILABLE FROM DRIVING A GEN II/2G "HYBRID $MART": 3 + 1.5 + 2 + (3 to 8) – (1 to 3) – (0 to 8) + 2 + 2 + 0.5+ 2 +3.5 = 8.5 to 21.5 MPG
    RANGE OF PER-TANK-FULL FUEL ECONOMY POSSIBLE FROM DRIVING GEN II/2G "HYBRID $MART":
    OFFICIAL EPA 46 MPG [Combined] + (8.5 to 21.5 MPG) = A "$MART" 54.5 to 67.5 Average MPG Is Possible
    Important Fuel Economy Point To Ponder Is: Anytime the internal combustion gasoline engine is not running and you are moving down the road, you are getting "Infinite" Instantaneous Miles Per Gallon Fuel Economy. This "Infinite" Miles Per Gallon is displayed as 99.9 MPG on the Multi-Function Display (MFD). Conversely, if the ICE is running constantly, as the HSD may cause it to do during high-speed driving or in extremely cold, frigid winter weather operating conditions, the Instantaneous Miles Per Gallon Fuel Economy will converge on the 30-35 MPG fuel economy inherent to the ICE itself.
    30-35 MPG (WORST) - YOU ARE DRIVING SOMEWHERE IN HERE - 99.9+ MPG (BEST)
    #14 catgic, Dec 15, 2016
  15. Corwin
    Avon, OH
    I really appreciate the helpful responses. I'll remove the roof rack this week and report back. I'll also look into many of the suggestions provided by catgic.
    Data Daedalus likes this.
  16. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    Corwin, . . . You may want to read about the Gen II's bladder gas tank. With Winter's cold here, don't be surprised when the Gen II Prius takes fewer gallons at fillup time.
    Enjoy your Prius, one of the best made cars ever.
    srellim234 and Data Daedalus like this.
  17. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    Great suggestions by everyone but those Cooper tires might be a genuine part of the problem. Those same tires were on our current Prius when we purchased it in April. I immediately raised them to 38 front, 36 rear psi and we still only got 34.8, 40.6, 37.8, and 39.3 mpg on our first four tanks before we replaced them with LRR Pirellis (the Coopers were really worn anyway and needed replacement). As you can see from my signature we've raised the overall average to 43.0 since them and that's with very little in the way of special driving techniques. A lot of short hops around town kills the mileage while most of our highway driving is done at 70 mph.
    Got2bHam likes this.
  18. Corwin
    Avon, OH
    Thanks everyone. I removed the roof rack tonight, so will see how it goes tomorrow. The tires will stay as is until they need replaced, but good to know that they may be contributing to the poor FE.
  19. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    Some of you guys are really optimistic about MPG.
    My wife is the primary driver of our '08 Prius. She makes absolutely no effort to drive any differently than she has any other car. The car has Michelin Defender (LRR) tires inflated to 40psi, has service up to date (plugs, air filter, fluids, etc.) and no Thule rack. She gets 44mpg consistently in warm weather -- 70% highway @ 70mph, and 30% 2 lane road @ 55mph.
    Now that winter's here, with studded snows it's 38-39mpg consistently. We're in Maine, so yes, it's cold.
  20. bisco
    49,489
    i don't think it's optimism, just observation. different conditions will give different results. defenders and female driving will almost always result in low mpg's.:p
    tvpierce likes this.
