Is this an acceptable alignment?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by famoustale, Dec 2, 2019.
  1. famoustale
    famoustale Junior Member
    31
    U.S.
    Pic:
    https://i.imgur.com/bHTfhys.jpg
    It looks to me like I have 3 specs which are out of range and some are borderline. But I don't know anything about alignments.
    Is this fine or should I go back?
    Thanks
  2. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    I see only 2 specs that are still out of range: FR caster and RR toe. They should explain to you why they are still slightly off and what it would require to correct the situation. Perhaps a suspension part is bent from hitting potholes or maybe something is worn out. It would not be unreasonable if you asked them to try the alignment a second time.
    famoustale and Bbonez like this.
  3. Mendel Leisk
    38,720
    As far as I know you can't do any adjustments with the rears, unless you start playing with shims, and that is not trivial.
    With the front the toe is readily adjustable, camber can be done too, but again, not trivial: it requires replacement of the two main shock/coil tower clamping bolts (with alternate, narrower Toyota bolts).
    The only things I can see an alignment shop doing in a routine alignment job, is to check and report on everything, and adjust front toe if needed.
    I think the attachment is just the front alignment info. If anyone's interested I can dig up the rear as well.
    #3 Mendel Leisk, Dec 2, 2019
    Pluggo, Robert Holt and famoustale like this.
