is this crazy or what?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mino54, Nov 17, 2008.
  1. mino54
    mino54 junior member
    el cajon
    i need help
    I did oil change was idling my pryus with the key in my pocket,my wife got into the car and drove off (THE KEY WAS IN MY POCKET).
    is it normal for the pryus once its started to keep running or been driven away without the key in range?
    how do i fix this?
    mino54
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This is normal. You don't fix it. Once started, the Prius (SKS models) can be driven until shut off. After that it won't restart without the key.
    Tom
  3. richard schumacher
    7,663
    1,038
    United States
    Wait: you were changing the oil *with the car ON*? If so then you have much bigger problems.
  4. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Yes, with the car on, the ICE could start at any time. If is starts while you've got all the oil drained.....
  5. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I'd say better communication with Wife would help.
    Perhaps a cover or tape over the steering wheel that indicates a Maintenance downtime interval is in play.
    Perhaps a traffic cone in the seat would be a hint.
    Or, some other indication not to take the car.
  6. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I'm going to make a wild guess that the OP had started the Prius after filling it with oil, so that he could check the oil level.
    Otherwise, wouldn't she have noticed his legs sticking out from under the car? :D
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Doooh!!!! its spelled "P R I U S"
