Is this dry rot beyond repair?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ericspoor, Jun 9, 2019.
  1. ericspoor
    ericspoor Member
    76
    37
    austin
    Is the dry rot on these tires bad enough to warrant replacing? Tread life is still great. The driver side rear leaks air over time. Thinking its time to get some defender t+h’s but dont want to shell out $$$ if you guys think its not as bad as it looks. Thanks for your insight!
  2. Mendel Leisk
    41,898
    WilDavis and ericspoor like this.
  3. Leadfoot J. McCoalroller
    8,145
    7,645
    Pennsylvania
    2018 Prius c
    That doesn't look awful in the photo, but could just be the photo. I agree with Mendel, let the date code be the deciding factor.
    ericspoor likes this.
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    If you are happy with the tires, I would keep driving them. That amount of cracking isn't going to cause a catastrophic problem. The Michelins on my VW were less than 4 years old and showing more cracking than that.
    Note that as tires get old, they lose some of the desirable tire characteristics as the rubber hardens. They may not handle as well, etc. But, if you aren't noticing any of that, keep going with them and inspect at least monthly.
  5. ericspoor
    ericspoor Member
    76
    37
    austin
    manufacture date is feb 2015-- that sounds recent enough to just let it be perhaps then?
    bisco and Rmay635703 like this.
  6. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Almost new. Drive them down to the wear bars.
    Put some soapy water on the valve with the cap off and see if it bubbles. This is a common source of leaks. I've also leak tested tires in the bathtub, but that's not real popular with the spouse.
    #6 jb in NE, Jun 9, 2019
    jerrymildred and ericspoor like this.
  7. ericspoor
    ericspoor Member
    76
    37
    austin
    great to hear, thanks for saving me the expense!
  8. Leadfoot J. McCoalroller
    8,145
    7,645
    Pennsylvania
    2018 Prius c
    Yep keep rolling and check again later.
  9. Mendel Leisk
    41,898
    Considering the age, they starting cracking early. Almost a defect? Maybe the tireshop that installed them can go to bat for you, get a pro-rated warranty replacement? Doesn't hurt to show them, see what they say.
    What are they, manufacture and complete model name?
    The Electric Me likes this.
  10. ericspoor
    ericspoor Member
    76
    37
    austin
    They are the goodyear assurance tires. tires were purchased by the PO couldn't say where they were installed unfortunately. Based on the dates/mileage of the car's oil change history, the car was hardly driven in the year or so prior to my purchase which I would guess contributed to the early rot, not sure.
  11. Mendel Leisk
    41,898
    Considering one has a leak, I'd be inclined to replace.
    I recently replaced some Pilot hx MXM4, sitll plenty of tread, but getting pretty cracked looking. They were OEM, and manufactured Feb of 2009, so I guess deserved their cracks. the car was built in August 2009, and sat till we bought in November 2010.
    Thing is, how much do you want to gamble on "they're probably ok"?
  12. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    From the picture, they are OK. And I doubt that a leak would be caused by that small amount of dry rot.
    #12 jb in NE, Jun 9, 2019
  13. bisco
    52,386
    texas sun maybe? i would keep them too.
  14. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    If your tire shop cannot find the leak have them check around the bead of the tire. I was having issues with a tire slowly loosing air and they needed to sand the inside of the wheel and clean it up a bit so the tire would seal to the wheel again.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Tires, IMO are one of the most direct safety related aspects to driving.
    So to me?
    It's comes down to Safety vs. Money. And I'm always going to side with safety.
    You've got tires exhibiting ROT...that by your own admission weren't used much for a year or so. If the vehicle was hardly driven, that's not good for tires. Lot's of sitting.
    Safety trumps frugality.
    IMO...replace the tires...KNOW they are good. Don't gamble that they are "good enough".
    Montgomery and WilDavis like this.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Goodyear Assurance tires suck. Awful ride could not wait to get them off my car. Buy some cheap Kumho's the car will ride 100% better.
    Sidewalls should not look like that picture. That would greatly concern me. Car has sat for a while.
    Ever had a blow out before?
  17. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes.
    I don't actually see ANYTHING that would concern me even for a second.
    Exactly what is it that you are worried about ?
    Tiny surface cracks are pretty much normal.
    Modern tire compounds do not "dry rot" anymore.
    By all means have a tire shop check the one that is losing air.......soon.
    Could be a puncture, valve stem or bead not seated good.
  18. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Michelins have a reputation in that the tread will outlast the side-walls. At least that's what I discovered when I was about to replace the Energy Savers on my 2009 Gen II (the second set of Michelins @ around 100k plus miles) Lots of tiny micro-cracks appearing on side-walls. Tread about 60% worn! :(
  19. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    To address the question in the subject line, you don't "repair" dry rot tires just replace them.
    Inspect the condition of the rubber between the treads. If you're also seeing deterioration there, let that be your guidance.
  20. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    There won’t be a blowout due to that small amount of surface cracking. I will bet money the inside walls of that tire look like new.
