Is this engine in good condition?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ingyaningya, Mar 3, 2016.
  1. ingyaningya
    ingyaningya Junior Member
    70
    17
    Miami
    I just bought a used 2007 Prius. I am by no means an auto expert whatsoever. Could someone please be kind enough to to tell me, by these pictures, if the engine is in good condition? All the fluids are at the proper level, this I know.
    Please do respond and ask me questions, I appreciate any and all help.
    Thank you.
    View attachment 106006 View attachment 106007 View attachment 106008 View attachment 106009 View attachment 106010 View attachment 106011 View attachment 106012 View attachment 106013 View attachment 106014
  2. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    There's a first for everything.
    Did it not cross your mind to PAY for a vehicle inspection from a reputable mechanic who specializes in Hybrids, esp Prius? You lack sufficient auto knowledge to make an informed decision. Scary to think you will decide based on pictures of the engine compartment alone.
    Try contacting member TampaPrius via PM (private message) function. At least he is in your State, and maybe nearby. If he is far away, he may know of a good mechanic near you.
    You apparently have not heard of CarFax either. Its a service you pay for to see accident history. Its not 100%, but it is better than nothing, and they have a guarantee to buy back the car if something big was missed on their report. But you have to know what the details are.
    Make the effort to educate yourself about cars and buying cars, esp used cars. Look at Edmunds, KBB (kelly blue book), Consumer Reports, as these sites have used car buying advice.
    You can also goto Toyota.com or your local Toyora service dept, to see service and recall history. The VIN will be required.
    EDIT: Crap, just realized you already purchased the car. Hope you didnt buy a salvaged or a car with problems to surface immediately.
  3. Melchior
    Melchior Junior Member
    74
    Netherlands
    It is basically impossible to discuss and engine's health just from engine bay photos. Unless there is e.g. a huge oily mess and a big hole in the side of the engine, any wear etc. isn't visible without taking the engine apart.
    However - there are some things you can do to get an idea:
    1) run the engine with the oil filler cap off and see how much air is pulsing in and out of the filler hole. There will be pulsing but if lots of air is flowing out then there is 'blow-by' which means either the breather pipes are blocked up (fairly easy to clean them) or the piston rings are worn (huge job, probably easier to fit new engine).
    2) Pull the dipstick out and see what colour the oil is. If very dark, change it and the oil filter. After 50-100 miles, check the dipstick again. If the oil is darker than when it went in, the engine is dirty which probably means the oil hasn't been changed regularly enough. Don't use an oil/engine flush product but change the oil (and filter) every few hundred miles until it stays clean for longer.
    3) Check for smoke out the exhaust when the engine starts from stone cold (i.e. been left standing overnight) and also under hard acceleration at high RPM.
    Also inspect the water pump belt shown in your 4th photo. If it is cracking, replace it. It's a very easy job and the belt is not expensive.
  4. RRxing
    RRxing Senior Member
    2,559
    1,833
    NEPA
    The engine compartment looks great!
