Is this misfire?
Discussion in 'Gen 2 Prius Main Forum' started by hans_fh, Aug 24, 2010.
  1. hans_fh
    hans_fh New Member
    51
    The engine started making weird noise at 1:20.
  2. Cheddaryodas
    Cheddaryodas Junior Member
    23
    Wisconsin
    Your post says 08, but in your vid it sounds like you say it's an 09?
    Doesn't sound like a misfire to me. What is the mileage and maintenance history for basic tune-up stuff?
  3. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    I always have the opinion if I don't know what I'm doing, I let someone who does, do it. Take it in to a mechanic. Probably be fixed in an hour. Mechanical things break/wear. In the forum you will get everyone telling you what is wrong. Doesn't fix the problem unless you are mechanically inclined and have all the right tools. Was this the one that was powerwashed?
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    is your hybrid battery staying charged? is your mpg the same as it used to be?
    the only thing i can think of is a cylinder not firing.. check the ignition coils.
    oil?...
