Is this necessary?
Discussion in 'Gen 3 Prius Main Forum' started by James4455, Nov 20, 2013.
  1. James4455
    James4455 Junior Member
    72
    San Angelo, TX
    I recently pulled against a parking curb (small concrete block in a parking spot). When I backed up, a post holding the block in place caught on a panel under the engine (p/n 51410-12105 Cover Assy) was torn off. A check with the dealership determined this cost $286 to replace complete with bolts and clips. Is it necessary to replace this panel? If so why?
    Another note: My vehicle is a 2013 Prius, I understand that means it is a 'Gen 3' but I keep seeing references to II or III or whatever that I assume refer to accessories or sub-model. VIN is if that helps. Dealership told me that all Prii come with satellite radio and I can't find that in mine. (purchased used from Enterprise Renta car, I know they order cars specifically equipped). I would like to add the option for sat radio.
    JMD likes this.
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Probably there for aerodynamics more than anything else.
    If it were my car, I'd try to get the part off of eBay or from a salvage yard.
    SCH-I535
    James4455 likes this.
  3. milesmutt
    milesmutt Junior Member
    34
    Silicon Valley, CA
    Yes, your car is a Gen III, or third generation Prius model. As far as I know, satellite wasn't available in the Prius Two.
    Dealerships tend to oversell rather than undersell.
  4. heyjack70
    heyjack70 Junior Member
    25
    Agreed. At a "pull your own parts" junk yard I bet it would probably cost less than $30. It would be useful to know if the 2012/2011/2010 models have the same panel.
  5. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    James perhaps a body shop can save you a few bucks. But then again the job may be too small for them to bother.
    Please hit the edit button on your original post and delete your vin number
    James4455 and elementnomore like this.
  6. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Mine was ripped off too. My fuel economy without was about 2 mpg more.
  7. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    211
    used to be "Glacial" Maine and now FL
    The now missing panel is most likely there for air flow management purposes. Prius are quite aerodynamic, so I imagine this cover is there in part, to help direct air through the engine compartment. I would replace it if possible.
    James4455 and JMD like this.
  8. James4455
    72
    San Angelo, TX
    Ok. I deleted the VIN number. But why. Is that a bad thing
  9. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Just for safety's sake but we are on the internet :sneaky:
  10. JMD
    3,779
    1,282
    James it is always smart to not post personal information on the Internet. Cyber criminals run unchecked and can hurt you in more ways than you can imagine.
    James4455 and DtEW like this.
  11. Les_PL
    Les_PL Active Member
    317
    248
    Gdynia, PL
    Right, in this particular case the potential criminal has for free the following information:
    Type and model of the vehicle, year of built, plant, how many doors, type and capacity of engine installed, fuel type and safety restraints. Paid services offers authorised service history of the car, police records (if any). I believe that more advanced individuals can find the personal data of current owner (home address and other particulars). Not to mention that having a VIN offers possibility to duplicate your FOB and mechanical key - hence the bad guy may pick your car as his own.
  12. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    ...Although it needs to be considered that a baddie can get a VIN number off of any car in a parking lot and have access to similar information.
    The real problem is when this information persists online, and you later share other info, like what you do for a living (registration address can be used to deduce where you work, esp. if you talk about your commute distance in some other thread later, etc.), and so on. It's the combinations later on that are the problem.
    xpcman, James4455 and Les_PL like this.
  13. Les_PL
    317
    248
    Gdynia, PL
    Oops, sure, I forgot that in many cars nowadays the VIN is exposed.
  14. James4455
    72
    San Angelo, TX
    Thank you everyone for the information
  15. vskid3
    vskid3 Active Member
    773
    228
    I found the part on rockauto.com for $40, search for the part number. I don't know if it comes with any clips, if not they shouldn't be any more than $10 or so.
    James4455 and B. Roberts like this.
  16. James4455
    72
    San Angelo, TX
    Wow. Thanks. I'll check it out
  17. B. Roberts
    691
    211
    That's the reason Prius Chat is such a great place to hang around in. If you need info... you're going to find it. Way to go vskid3!
  18. James4455
    72
    San Angelo, TX
    I don't find anything for part number 51410-12105 which is the part quoted from the dealership. Is there another number I should try?
  19. vskid3
    773
    228
    Strange, I can't find it now, either. I checked under the 2013 Prius in the catalog and it wasn't there. They might be out of stock. You could try sending them an email or check again in a few days.
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    At least in my area?
    The problem with "Pull Your Own Parts" places is the competition for any parts of value is so fierce that you almost have to happen to be there at the exact moment the vehicle with the part you want might happen to arrive.
    "Professionals" are waiting to strip the vehicle of almost any and all parts of value like Piranha.
    I've only been able to really have some luck with some obscure "cosmetic" parts. Sometimes they get left. But going to find any part of real value at a "Pull It Yourself" place has always been a losing endeavor for me.
