Is this noise normal while braking?
Discussion in 'Gen 2 Prius Technical Discussion' started by fullylaced1, Jun 26, 2020.
  1. fullylaced1
    fullylaced1 Junior Member
    31
    Los angeles
    When I stop at a light or brake while idling I hear a noise from what I believe is the ABS actuator. Is the actuator suppose to make this noise consistently like this? it will usually come on for a few seconds when I either brake or take my foot off the brake pedal from a stop. I do not have a check engine light and I have checked the codes on Techstream and theres no codes.
  2. ChapmanF
    18,519
    Not so easy for me to listen to the imgur link, but is it a single run of a few seconds usually when you apply or release the brake, or is it cycling like that over and over while you sit there stopped with your foot held on the pedal?
  3. fullylaced1
    31
    Los angeles
    The sound will come on when I only apply/ release the brake pedal and doesn’t go on if I’m just sitting without applying the brakes.
  4. ChapmanF
    18,519
    Not necessarily a concern. I usually describe mine as running every 'few' uses of the brake, but how many is a 'few' can depend on a lot of things (how hard the brakes are applied, pad clearance or rotor runout in the front, adjustment of the rears, etc.), plus it is not super loud and I'm sure there are times it runs that I don't notice it ... maybe most of them.
    ... which means the more attention you pay to it, the more it can seem to run, which can be a kind of obsessive spiral.
    You can find threads where it has developed an obvious problem, and will sit there continually cycling without additional use of the brakes. If it gets there, or you get warning lights and the beeeep, you'll know it's a problem then.
    SFO likes this.
  5. fullylaced1
    31
    Los angeles
    I probably have been paying too much attention to it and think the worst. Thanks for your insight!
  6. ChapmanF
    18,519
    By the way, do you routinely use the parking brake when you park?
    The way the rear brake adjusters work, there have to be applications of the parking brake, mixed in with applications of the regular brake. If that doesn't happen often enough, the rear brake shoe clearance will increase ... which uses more brake fluid every time you apply them ... which runs the pump more often.
  7. fullylaced1
    31
    Los angeles
    Yes I do use the parking brake regularly, but I just got the car so I’m not sure if the previous owner did. Thanks again!
