Is this normal after unhooking the HV battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by codycowgill, Mar 22, 2016.
  1. codycowgill
    codycowgill Junior Member
    Rexburg, ID
    Hello, I recently cleaned all of the corrosion off the copper bus bars on my traction battery. When I got everything put back together I went to start the prius up and got the red triangle. I then remembered that I forgot to plug the master orange switch back in. After doing so I still had the red triangle so I turned the car on and off a couple times and it went away. Is this normal behavior from forgetting to put the master switch back in an attempting to turn the prius on?
  2. 48mpg
    48mpg Member
    193
    46
    florida
    I
    did you push the lever down until it clicked?
    Im sure theres a video on youtube somewhere you can watch to make sure you are doing it right
  3. hill
    8,187
    At what point was the 12v aux battery connected / disconnected ... it sounds like codes got recorded that the hv pack was nil.
  4. codycowgill
    Rexburg, ID
    I did push the lever down yes but as for the 12v battery...well I forgot to unhook it...whoops! Did the code get erased by turning the car on and off?
  5. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Yes. If the original condition that threw the code no longer exits, then "x" number of power cycles will clear the light.
    codycowgill likes this.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    At 3:55 to about 6:00 he discusses the service plug
  7. codycowgill
    Rexburg, ID
    Thanks for the help all! And that video is very informative. The Vids he has about the CVT are also very cool.
