Is this normal for middle seat buckle to be this long? Trying to install car seat
Discussion in 'Gen 3 Prius Main Forum' started by ja7777, Sep 3, 2017.
  1. ja7777
    ja7777 Junior Member
    cape town
    I am trying to get a middle car seat installed in my 2010 Prius and It is almost impossible to get it to be secure in the middle seat as the length of the middle clip comes out so far and goes up inside the seat belt path of my diono radian rxt's.
    Is this what your middle buckle looks like? It is also weird because the middle buckle is actually on the left side and the left buckle is in the middle. I've pulled out the seat to confirm this is how they are bolted into the frame.
    Also, because the middle seat belt does not have the tension like the left and right, I have found the only solution is to use the metal seat belt stopper on the belt, but this makes it a massive pain to put the seat in as the buckle goes up inside the seat and the stopper prevents you from being able to extend the seat at all.
  2. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    i don't know but to me it looks broken
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    That's not normal, I would try to find a replacement buckle.
    ja7777 likes this.
  4. Mendel Leisk
    38,711
    The Radians also come with the other clips? I always call them cig lighters, forget what they're actually called.
    They're the PREFERRED connection method. Feel in between seat and backrest, for strategically located u-bolts, that those snap onto. There's ideally a little button on seatback to show their location.
    When cinching the seat down, put a knee in the seat and put all your weight on it, get it as tight as possible.
    Not seeing buttons in your pic, but check.
  5. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Go see the Dealership if it's broke. Look it up...Toyota has a Lifetime Warranty on seat-belts.
    ja7777 and Mendel Leisk like this.
  6. ja7777
    cape town
    Thanks, but they don't have them in the middle seat. only the sides.
  7. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Perhaps the middle position is not designed for a child safety seat. What advice does the manual give?
  8. Mendel Leisk
    38,711
    Yeah you're right.
    I'm pretty sure we had three Radians in there (for grandkids), at least once or twice, and I seem to recall using only the "LATCH" (Lower Anchors and Tethers for CHildren). I had a look at ours and yes, there's only U-bar latch points at the two outside seats. BUT: they're quite wide, about 1.5 inch, and I believe what I did was double up on the inside ones, use the LATCH connectors from two seats.
    Prodigyplace and Raytheeagle like this.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Toyota doesn't recommend using LATCH in the center position. Most manufacturers don't as well. The anchors are spread farther out if used in the middle than if used on the sides. This decreases the strength of belts attached to anchors in the middle seat. I use the middle seat belt for the middle position. Only use the middle anchors if there is a dedicated pair of LATCH anchors for the middle position.
    I suspect the middle seat belt got misrouted underneath the rear bench seat. Seat belts are one of the toughest components in a car. While possible, it's unlikely to be faulty.
  10. Mendel Leisk
    38,711
    I was thinking that too. I went out and measured, the centre-to-centre dimensions are 11", 16", 11". Still, in practice using LATCH for three abreast Radian seats (they are quite narrow), the angle of the centre seat straps didn't seem too splayed out.
    You're right, but still: it was solid as heck (technical engineering term, lol). Especially if you put your knee and all your weight on the seat while cinching the slack out of the LATCH strap.
    mmmodem likes this.
  11. mmmodem
    2,732
    1,703
    Bay Area, CA
    I doubt the difference will make-a-lick-of-a-difference (also an engineering team) considering the mass of a toddler and the car seat. I really think it's just a CYA exercise for the lawyers. I use three seats abreast with a Diono Radian in the middle. Since you can't double up on a LATCH anchor, the only way is to use the middle seatbelt for the center position and LATCH on the sides.
