Is this normal?
Discussion in 'Gen 3 Prius Main Forum' started by Mare1083, Jan 4, 2012.
  1. Mare1083
    Mare1083 New Member
    Illinois
    Hi!
    I just got my first Prius, a pre-owned 2010 Prius III. I filled the tank right after we got it and reset the trips. I've only put about 225 miles on it, but I noticed something. Is it normal for each tank to start low and grow high? I think it started out around 32 and I've gotten it up to 39.1. I've been reading a lot, but I still don't quite understand how to drive it. From what I've read, I think I use the battery too much. :(
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Mileage going up over a tank isn't normal, but it's not unusual either. It all depends on conditions: Is the engine hot? How fast did you drive? Short or long trip?
    There isn't one right answer.
    Tom
  3. GBC_Texas_Prius
    218
    38
    gbc texas
    When I drive the Prius, I try to hypermile some. When my wife drives the car, I'll look at the "tank" and it's usually at a higher number then I left it. That's the beauty, you don't have to think about it that much, just go with it and enjoy.
    Answer to your question, your experience doesn't seem to be unusual. Sometimes I start at a low figure and end up higher and other times I start high and end lower.
  4. Mare1083
    Mare1083 New Member
    Illinois
    OK, thanks. I'm still reading about "how" to drive it. I'm not sure I'm doing it right. I've kept it in ECO mode. My avg speed for the 39.1 was 23 mph. The weather hasn't been great here (we had a couple days in single and low double digits with super cold windchills). I didn't drive much then. I'll be starting my almost daily 70+ mile trips here in the next couple days.
    I think I maybe use the battery too much. I think I try NOT to use the ICE. I'm going out to check tire pressure now. We just bought it 5 days ago, so much to learn!
  5. GBC_Texas_Prius
    218
    38
    gbc texas
    An obvious point I forgot to point out, if I drove over 200 miles and was getting less than 40 mpg in any weather, I would check tire pressures. Sometimes I can tell when my tires are a little low just by looking at my mileage chart.
  6. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    As mentioned, there are many variables which contribute to (or detract from) MPG or miles per tank. As you continue to drive your Prius, you'll develop a better sense of what affects it. Don't be overly concerned about it, just enjoy the ride!
  7. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    The avg cons. number can move around a lot with few miles on the trip.
    For example, I gassed up other night, reset. We hit the freeway 8 miles North, then began about a 8 mile freeway climb up the hill. Gage got down to 43 MPG (always hate to see that). But, when descending down, it climbed up to 49. Return trip back home, was up to about 50 or so.
    Hit your display button until you see you Hybrid System Indicator gage. You want to keep the bar out of the PWR zone to the right. When accelerating, it's ok if the bar is at upper portion of ECO zone, but not bured into the PWR zone. Toyota says, when able, lift off accelerator a bit and let the bar go under the halfway point to catch EV if able. But don't try to get EV too much, just on those really smooth streets under 40 MPH, if it wants to do it.
    Set your tires to at least 38 psi front/36 rear with a decent gage (can get good enogh gage for $9).
    Very short trips (2 miles, 4 minutes) in 50 F weather drag my gage to upper 40's MPG.
    In the 30s MPG is pretty low. That indicates extremely short trips, very cold weather and lots of heater use, low tire pressure or something else.
  8. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Even a lightweight 1 gallon air compressor will help keep the tires inflated. Got mine for $50. Hate going to gas stations for air, yuck.
    I know nothing about low single,double digit weather. Don't mean to rub it in, but we're seriously spoiled with 50F+ daytime :eek:
  9. Mare1083
    Mare1083 New Member
    Illinois
    Thanks for the info! Hubby has a portable 3 gallon plug in compressor and then a not so portable giant 20 or 30 gallon compressor. He's airing it up right now. The current pressure was 30 in front and slightly lower in the back. Hubby brought home some special gauge from work (he's a mechanic, works mainly on Saturns, but his dealership is now officially Subaru since Saturn discontinued). It took me a LONG time to get him to even consider the Prius, but now he's talking about getting a plug-in version when we pay our truck off in a couple of years.
    Here in the northern Midwest this has been a really mild winter. Most days temps are 30-40s but we had a real cold spell over the weekend when we bought the Prius. I will try to stay away from the pwr bar. I try to keep in the left side of the "ECO" bar, but then I think that runs the battery down too much. I'm hoping my next tank is better. I traded up from a Saturn that got 25ish winter and 30ish summer mileage. I'm hoping to do a lot better in the Prius. 45-50 would be amazing!
  10. oldasdust
    oldasdust Member
    356
    47
    illinois
    What i have found to be the biggest mpg factors for me are tire pressure and wind, especially on the highway. I have had swings from upper 30's to upper 60's.
  11. bisco
    49,485
    check your 12v battery to make sure it's up to snuff. 2010's are notorious for bad batteries and that can reduce your mpg's.
  12. Mare1083
    Mare1083 New Member
    Illinois
    After adjusting the tire pressure to cycledrum's recommended 38/36, my cons. mileage is now 40.5.
    I do have another question though. I read somewhere that the Prius builds a "memory" to how it is driven. On my car, one of the chart screens that says Trip A Past Record (I have a picture but don't know if I can post it or not) shows BEST 44.5 (1676 MI).
    Since I bought this car used, would it have been "memorized" to the previous owner? I've heard that unplugging the battery will reset the memory. Are any of the radio presets or bluetooth contacts removed when the battery is unplugged?
  13. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Hilly terrains and short trips can also result in poor mileage. I've been averaging high 30s on my commute in 35-40F temps, but got 55 on a 10 mi trip downtown during lunch (flatter, 65F out).
  14. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Yes, thats normal. when I refuel, I reset trip A to monitor tank to tank mpg. I only reset trip B at 10,000 mile oil changes, so I have a long term 10,000 mile mpg average.
    When I refuel and reset trip A, as i drive off ,it usually starts in the 20's-30's and slowly works up to 50+ mpg after a few miles of running on the cruise control.
