is this normal?
Discussion in 'Gen 2 Prius Main Forum' started by brokenheart, Nov 7, 2005.
  1. brokenheart
    brokenheart New Member
    Just got my Prius 2 days ago. today I am hearing clicking sound when power up and when power down. clicking last about 1 min. Is this normal?
  2. DaveG
    DaveG Member
    806
    Vancouver, BC
    There are a few noises it makes when powering up/down:
    -Coolant storage pump working
    -HV relay engaging / disengaging
    -Inverter assembly (clicking/buzzing sound)
    -Brake system pressurizing
    I wouldn't worry about it - the Prius is absolutely loaded with diagnostic sensors. If it's doing something it shouldn't, the display with light up with error/warnings.
    Dave
  3. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    Correct. It's a pump. No worries.
    You may also hear a "whirring" sound. Also normal. It's sometimes unnerving getting used to different sounds made by different cars. The Prius is no different, and in fact offers (at no extra charge!) sounds you won't hear on most other cars.
  4. aka007ii
    aka007ii New Member
    482
    Santa Clarita, CA
    I haven't timed it but I think it takes about a minute after shut down and then you hear a swoosh followed by the pump ticking (sounds like a small air compressor). I once caught a woman talking to my car once it started making the noises. Only in Hollywierd.
  5. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    When I first got Priapus, I noticed similar noises when I started and shut down. In my case, though, it turned out to be the jaws of my neighbors hitting the ground when they realized that the engine wasn't running.
  6. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :) Howdy brokenheart
    ...and WELCOME to the "Wonderful World of Prius Ownership..!!"
    The sound you hear is most likely the coolant pump pumping hot coolant into and out of your ICE (Internal Combusion Engine). It is perfectly normal for the Prius.
    Take a look at your Owner's Manual - Section 3 - "Information Before Driving Your Toyota" Page 208 (2004 Manual) - "Coolant heat storage system" paragraph reads in part: "The coolant heat storage tank system stores hot coolant and feeds it via the electric water pump automatically to warm the engine as required."
    Although the Owner's Manual is not an "easy read," there is a great deal of useful, informative information therein. I made it a practice of highlighting interesting information and writing in my own "Index" on the back cover for reference. The Index provided seems a bit strange sometimes.
  7. finkj
    finkj New Member
    24
    To all,
    I just installed the factoryinteractive sirius and now i hear the same clicking coming from the bakc of the car (interior) when i start up and shut down. Relay sounds like a good answer. I need some reassurance from someone that I didn't ruin something...help.
    There are no warning lights.
    Jon
    <div class='quotetop'>QUOTE(brokenheart @ Nov 7 2005, 03:49 AM) [snapback]151853[/snapback]</div>
  8. Walker1
    Walker1 Empire
    911
    FL
    Yes, quite normal. Your Prius will make lots of funny sounds. It has a personality that "speaks" out to you from time to time. Enjoy your new car. It's a fun vehicle to own.
  9. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
