Is this normal?
Discussion in 'Gen 2 Prius Main Forum' started by blacktouring, Jul 25, 2009.
  1. blacktouring
    blacktouring Junior Member
    45
    Rolling Hills Estates
    I just took delivery of a used 2007 Touring. I noticed on that on either side of the dash, adjacent to the A pillars, there's a small triangular shaped plastic sheet coming from beneath the dash. I would assume this is NOT how the car came from the factory - or is it?
  2. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    This is purely a guess as far as the Prius is concerned, but manufacturers cover some of the interior when the car leaves the factory. In Ford's, I've seen not only seats, but various other areas of the interior surfaces covered this way. And, on those, sometimes the plastic was anchored by its being pushed into a seam from one panel to another. More than once I went through a car getting rid of the residual plastic left when the dealer's prep person simply pulled at it until it broke off wherever it did.
  3. TheForce
    3,461
    537
    Wheelersburg, Ohio
    You can remove the plastic. I had to remove one from my car. I did not notice it for months.
  4. Patrick Wong
    18,200
    6,480
    That is how the car came from the factory. I've left the two plastic triangles on my 2004 but if they bug you, then you can remove them.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i had a lot more plastic in my car. the only good thing from those particular pieces you shows is that it may keep that dash piece from rattling. those areas lift up rather easy, and did rattle for a few months in my 04. eventually all rattles did kinda go away.
  6. blacktouring
    45
    Thanks everyone for your prompt replies. Just got back from my mechanic and as I suspected, this car was in a front end collision. My mechanic did say that it was very well repaired - paint job could be a lot better though. My mechanic says I really shouldn't get my panties in a bunch since I picked up this car for $15K, interior is really clean and has only 17K + miles. Getting over 50MPG certainly helps take the edge off!
  7. Patrick Wong
    18,200
    6,480
    That's a great price for a 3-year-old car with 17K miles...if it has a clear title.
