Is this puddle deep enough cause any damage?
Discussion in 'Gen 5 Prius Main Forum' started by theRob, Jun 15, 2024.
  1. theRob
    theRob Member
    88
    103
    2023 Prius
    It did not seem deep enough and I drove pretty slow. I had no issues with the car so far.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    899
    501
    Cow-lee-fornia
    2023 Prius
    No. I've gone through deeper. If you need to get through more than say 3 inches of standing water, go slow. The engine will shut off and the car will go into EV mode and the risk of hydrolock becomes nil.
    GcinFl and theRob like this.
  3. Gokhan
    Gokhan Senior Member
    4,613
    1,853
    Paramount CA
    Technically, if you need to do this regularly, you need it trade it in for this:
    theRob likes this.
  4. theRob
    theRob Member
    88
    103
    2023 Prius
    Thanks. Just got worried. But not worried so much water entering the engine since the air intake is pretty high up. More concerned about water getting near the plastic panels on the bottom of the car. If there is anything there that water would damage it?
  5. HacksawMark
    HacksawMark Active Member
    439
    287
    Oregon
    2023 Prius Prime
    XSE
    I'd say as long as no water entered the cabin, you should be fine.
    theRob and Trollbait like this.
  6. kenmce
    kenmce High Voltage Member
    1,527
    502
    NY
    The car is fine with being splashed with water, which is what you did. Being submerged would be different.
    theRob likes this.
  7. Paul Gregory
    Paul Gregory Active Member
    426
    116
    Alberta
    2024 Prius Prime
    XSE
    #7 Paul Gregory, Jun 22, 2024
  8. Zeromus
    Zeromus Member
    346
    164
    Ottawa Canada
    2024 Prius Prime
    SE
    I think the rule of thumb is to not exceed half the height of the Wheels or above the door sills such that it enters the car. For any car, really.
    Now you know a road section to avoid in heavy rain at least.
    theRob likes this.
  9. PriusPeep
    PriusPeep Member
    97
    67
    New Jersey
    Just make sure to avoid driving like this… it cracks me up every time.
