Is this right? Timing gears
Discussion in 'Gen 2 Prius Main Forum' started by Redhouse7, Mar 2, 2025.
  1. Redhouse7
    Redhouse7 Junior Member
    20250302_151147.jpg 20250302_151139.jpg 20250302_151129.jpg 20250302_151116.jpg
  2. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    It actually looks like you're one tooth off on the cam gear pull it back one tooth I do believe that's what I'm seeing If not then it's just the camera angle and you should be good once you put the guides up and take up the slack on the slack side then you can rotate it around and I can't remember what it is every so many times all the mark should come back to alignment and you go around again whatever it is nine times seven times something and it should line back up
  3. highmilesgarage
    highmilesgarage Active Member
    427
    155
    Kansas City
    exhaust cam is off tooth, the mark should align "in between" the marked chain.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
