Is this sound normal?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by newtothisprius, Jun 19, 2023.
  1. newtothisprius
    newtothisprius Junior Member
    59
    My Prius is making a new sound. I'm curious if anyone can decipher what that is.
  2. Tombukt2
    Tombukt2 Senior Member
    8,916
    1,553
    Durham NC
    I don't know what are you think it is It doesn't seem to change with the change in the reciprocating mass of the engine transmission and drive axles so it seems kind of steady like possibly a wheel bearing air flowing up through the fenders God knows does it do it when you're sitting still what happens if you put the wheels up off the ground on jack stands or the car up on jack stands at the jacking points and the wheels turning going nowhere car running You still have the noise while the car's not going down the road but the tires are turning by the transmission and car running You still have the noise aha.. ?
    49,371
    sounds normal to me, prius are noisy
