Is this the correct LED bulb for parking and license plate light?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by us_matrix, Apr 1, 2011.
  1. us_matrix
    us_matrix Member
    110
    http://www.ddmtuning.com/Products/194T10-White-LED-Bulb-5x5050LED
    I ordered two from DDM and tried last night on parking and licnese plate light. But none of them are working. Is it the correct one? I tried insert the LED bulb to different direction but still not working. Wonder if it is DOA or they are wrong item. Anyone knows?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    If it fits in the socket, it should be the right bulb.
  4. silica
    silica Junior Member
    44
    Phoenix
    How did you know this was a replacement? Nowhere on the page does it show that it is a replacement for a W5W, which is the bulb size from the owner's manual.
    I'm tryiing to find a LED replacement for the rear turning signal bulb. I bought a 7440 LED bulb but it is too large to fit into the housing.
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I do not know or actually remember how but when the Gen III was first coming out and we found out info about it we tracked down that this was the bulb. From what exact information we deduced this was the bulb I'm sorry but off hand I dont remember. But we did in many posts talk about this being the bulb which works for the parking lights, rear license plate light, front door lights and map lights. When you start talking LED for turn signals you get into more mods because of the current. I didn't go LED but went with bulbs coated in a mirror finish so you don't see yellow in the rear or front turn signal lamp housings. Myself and others have used them and posted about them with pics. I think they were called Philips Silver Vision.
  6. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    W5W = Wedge 5watt White (I believe) or something along those lines.
    It's the same as the T10, 168, etc bulbs that are all compatible with each other. So, yes, the bulb listed is correct.
    It could be that the bulb isn't far enough down in the socket. I've noticed the LEDs tend to have an every so slightly larger base section and need a little more "oomph" to get them into the socket correctly.
  7. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    The 7440 is the correct bulb but some manufacturers have made the LED's stick out too far to fit through the hole. I found that to be the case with Superbrightled's W5W replacements for the front parking lights. Have found some others on eBay, but not liking them as much as I'd hoped. May try this DDMTuning place. Theirs are a nice slim fit. May just have to search around. Tons of places are carrying the LED replacement bulbs these days.
  8. Corwyn
    2,171
    659
    23
    Maine
  9. silica
    44
    Phoenix
    Thanks for everyone's information (individual thanks given in each post).
  10. wick1ert
    1,311
    183
    Delawhere
    I used these in my parking lights: 5 Chips 194 LED Bulbs
    They worked just fine, but the drivers side keeps blowing whatever LED bulb I put in it
  11. us_matrix
    us_matrix Member
    110
    Problem solved! It is the right LED bulbs. The problem was the contact between the LED bulb and the socket. Thanks for LulzChicken ^,^ suggestion of bending the LED contact upward. All good now.
