Is this the end?!
Discussion in 'Generation 1 Prius Discussion' started by Gbest, Jan 21, 2016.
  1. Gbest
    Gbest New Member
    Portland Oregon
    2002 Prius
    I
    I have a 2002 that I picked up cheap last year while working a courier job. Two days ago the dashboard lit up with the warning, check engine, PS, arrow through the car, you name it. It's got a 3008 (?) code, inconsistent battery levels. So I have I guess three questions. 1. With 190000 miles on it is there any chance it's not the main battery? I've watched various YouTube videos that suggest switching relays etc. 2. I bought it for $3000, I'm guessing it's not worth replacing battery?? 3. How long have I got?! I've driven it 60 miles since "I saw the light" runs fine but I imagine that it will just stop here soo
  2. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    ... Flatlining... Clear!...flatlining... Clear!...
    I regret to inform in you that it was pronounced dead at 7:30 pm.
    J/k
    Check your 12v battery.
    iPhone ?
  3. Gbest
    Gbest New Member
    Portland Oregon
    2002 Prius
    I
    12V seems fine, at least for now.
  4. DRACO
    DRACO Member
    362
    77
    Rancho Palos Verdes, California
    2002 Prius
    Well, it does sound like some like HV battery's one or more of the modules are failing or failed. But that is a strange CEL Code. Did you get this from a OBD2 or TIS reader?
    In any case, you need a more detailed state of your HV battery. Go to the Prius Gen 1 sub forum, allot of info there.
    Generation 1 Prius Discussion | PriusChat
    #4 DRACO, Jan 22, 2016
  5. lifehouse
    lifehouse Junior Member
    92
    GA
    Howdy mate! I would have the battery checked for consistently getting charge.
  6. 48mpg
    48mpg Member
    193
    46
    florida
    I
    sounds like the blinker fluid is getting low causing the battery to electroplode..
    I would look on craigs list for a local person to rebuild the battery for around $500, or do it your self for around $50 following the you tube videos and order the cells on e bay..
    but first remove the 12 volt battery and have it tested...anything below 12 volts under load means it needs to be replaced.
  7. bwilson4web
    15,513
    If the car meets your expectations, that should drive your decision.
    With a Toyota battery, you'll have a one year guarantee on the replacement battery. Rebuilder warrantee varies. Then if you can turn a wrench, you could do it yourself. Use the search function to see what others have done.
    Fixing the traction battery does not mean another part won't fail (or you won't be in an accident that totals the car.) Used cars are like that so it really comes down to a personal decision based upon your personal situation. Still, we've tried to include some guidance here:
    Who should and should NOT buy a 2001-03 Prius | PriusChat
    Having tools, a place to work, and alternate transportation, the rest is just time and motivation. You've found a good resources for Prius expertise. You might consider an independent mechanic by contacting:
    ACDC Hybrid Shop Program Qualification Process | Auto Career Development Center
    #7 bwilson4web, Jan 22, 2016
    S Keith likes this.
  8. usnavystgc
    3,159
    989
    Tucson, AZ
    It sounds to me that this might be a perfect candidate for Jeff's grid charger. 3008/inconsistent battery levels means he's outside the .3v variance allowed by the system but, from the sound of it, no cells are dead. Grid charging should restore this capacity.
    What do you guys think?
  9. usnavystgc
    3,159
    989
    Tucson, AZ
    The quick way to tell would be to observe the "Energy" display and see if its going from full charge to empty very quickly. Other symptoms of a dead cell would include HV fan always on high and engine revving. If he doesn't have those symptoms, there is no dead cell but rather just an imbalance.
    S Keith likes this.
  10. Gbest
    Gbest New Member
    Portland Oregon
    2002 Prius
    I
    Thank you all for your input. I'll get the 12V battery checked out as the first step. The car is running fine, still, no revving, fan not on high, cruise control has stopped working though, no idea if that can be related.
  11. usnavystgc
    3,159
    989
    Tucson, AZ
    S Keith likes this.
  12. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Cruise control not working is "connected". When the computer identifies a weak HV (traction) battery it puts the Prius into a "limp" mode where it reduces the use of the HV battery to keep your Prius running until the HV battery can no longer start the ICE and you need a tow.
    JeffD
    S Keith likes this.
  13. jeff652
    jeff652 Senior Member
    606
    623
    Idaho
    We have a lot of Gen1 Prius owners/battery rebuilders using our products. The batteries are quite aged and often a few modules or more need to be replaced. By reconditioning the battery, load testing/replacing failed modules (if any), and then cycling the pack again a couple times to equalize everything, it should not be difficult to get the vehicle back on the road.
    It's critical to keep maintaining the battery afterwards with regular charge and/or reconditioning sessions or else other modules in the pack will likely follow suit.
    S Keith likes this.
  14. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,219
    Madison, Wisconsin
    This is the part that many people ignore and pay dearly for it by playing "whack-a-mole" as other modules become out of blance or die over time.
    S Keith and jeff652 like this.
