Is this wheel bearing noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nsprius, Feb 15, 2016.
  1. nsprius
    nsprius Junior Member
    29
    Halifax Nova Scotia Canada
    Hi there. My rear passenger tire spins easily and makes noise. Here is the link to video.
    Dropbox - 20160215_143832.mp4
    SM-N910W8 ?
  2. arescec
    arescec Active Member
    238
    105
    Croatia
    Grab the wheel at each side and try to wiggle it. But yes, sounds like bearing.
    CrniMilorad likes this.
  3. nsprius
    29
    Thank you arescec . I didnt get a chance to check this until today. I had thought it was my winter tires. I hope to get thos teplaced ASAP and the noise will go.
    SM-N910W8 ?
  4. CrniMilorad
    CrniMilorad Junior Member
    Technology
    try to wiggle it as arescec said, and it sounds as something is quite loose
    Be careful if when replacing hub. It might we quite tough to take off speed sensor cable off hub.
    I replaced bub and cable together and did not have problems.
  5. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Assuming the Canadian 2009 is a GEN III (like in Europe) and because it posted in the GEN III section, changing out the rear bearing/hub assembly is quite easy. Do both sides at the same time though...if that is indeed the problem.
  6. nsprius
    29
    Yes it is a 2010 Gen 3. I canr seem to change my profile
    SM-N910W8 ?
  7. frodoz737
    4,297
    2,348
    33
    Easy money fix then if you know how to turn a wrench...and that is the problem. Gen II had drum brakes in the rear, so just a little more work there.
