Is Toyota WS Fluid "Liquid Gold"?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tnt01prius, Aug 25, 2022.
  1. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    Is there a good discussion about an alternative to Toyota's WS fluid, which seems to be leading inflation indicators? Has someone found a known safe alternative? I mean I drive a 2005 Prius for a reason. $13.11/quart is just not reasonable to me. Ideas? Please, I don't need to know how cheap it is per mile. Thank you.
  2. JC91006
    16,474
    8,393
    I pay about $10 a quart at my local dealership. 4 quarts about $40. This lasts me 60k miles before I have to do it again.
    But you know Toyota calls this stuff their lifetime fluid, you don't even have to spend the $40 if you don't want to.
    VFerdman and Mendel Leisk like this.
  3. JohnPrius3005
    JohnPrius3005 Active Member
    414
    224
    California and Hawaii
    You’re talking about windshield washer fluid, right?
  4. dolj
    dolj Senior Member
    7,627
    3,848
    Wellington, New Zealand
    There have been numerous discussions, but no definitive answers. A few people have used alternative fluids with seemly no adverse impacts. For me personally, when I priced alternative products they were either not cheaper or barely cheaper. Secondly, my take on this is per km/mile it is not a lot and given I'd only be doing this once or twice, I couldn't be bothered trying to save a couple of cents per km/mile.
    Nope, it is the transmission fluid used in the transaxle.
    #4 dolj, Aug 25, 2022
    jerrymildred and Merkey like this.
  5. farmecologist
    farmecologist Senior Member
    1,946
    1,785
    Southern MN
    Honestly...just use the Toyota product. Changing the transmission fluid is one area you don't want to skimp. Plus, changing it out is something that is only done once or twice for the life of the vehicle ( or never if you ask Toyota :rolleyes: )...so not worth fretting over a few dollars. (y)
    Doug McC and Merkey like this.
  6. ChapmanF
    15,402
    The "WS" in this thread is Toyota's "World Standard" transmission fluid. Bit obscure, possibly, to the uninitiated. :)
    JohnPrius3005 likes this.
  7. Mendel Leisk
    38,634
    It is the “elephant in the room” though.
    VFerdman likes this.
  8. JC91006
    16,474
    8,393
    Just use the gas savings to pay for it. Gas prices have gone down significantly from their highs 2 months ago. So just think of filling up at the prices from 2 months ago when you buy this WS fluid.
  9. Mendel Leisk
    38,634
    It was $9.14 CDN for me, per liter, back in September of 2016. But it’s gone up recently, and I can’t recall exactly how much. Maybe $11~12.
  10. PriusCamper
    PriusCamper Senior Member
    11,055
    4,498
    Pacific Northwest, USA
    I bet if we did enough research we'd find the manufacturer that Toyota buys from and then probably sell to more than one label... And of course the theory is because you got magnets and copper windings inside this transmission that the fluid needs to be different than standard transmission fluid. But has anyone done research on what specifically is different compared to standard?
  11. farmecologist
    1,946
    1,785
    Southern MN
    The consensus around here has always been to just use WS and not worry about the cost....I'm sure you know this as well since you have been around here got a long time. (y)
    As I said above, a transmission fluid change literally only needs to be done once or twice for the life of the vehicle. And millions of them that have never had it done ( per Toyota ). In fact, the only ones that are changing transmission fluid regularly are some of the 'enthusiasts' around here.
  12. Tombukt2
    Tombukt2 Senior Member
    8,876
    1,549
    Durham NC
    I use the I'm not sure what brand it was but it's a universal CVT fluid that covered every standard in the mix on the bottle including the Toyota. low you know not catch fire kind of thing. Or electrical conductivity problems
    PriusCamper likes this.
  13. dolj
    dolj Senior Member
    7,627
    3,848
    Toyota has cars with conventional CVT boxes. You need to be clear that the 'equivalent' to which you are comparing is the ATF WS fluid. I've seen aftermarket labels that claim equivalency to Toyota ATF WS, so would be comfortable using them. The fly in the ointment is they were not cheaper than Toyota's ATF WS. A case in point is Redline D6 as used by edthefox5.
  14. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,148
    2,202
    Taylors, SC
    Think WS is expensive. Check out the cost of Toyota FE CVT fluid.
    Genuine Toyota Parts - CVT Fluid Fe 4L (08886-02505)
    $106.67 ($3.33$3.33 / Fl Oz)
  15. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    Good points. Thank you all for the information. BTW, I still have a quart of the ATF Type T-IV (recommended for the Gen I Prius), which I sold last year. Is that stuff compatible with the WS?
  16. JohnPrius3005
    414
    224
    Thanks
  17. Tombukt2
    8,876
    1,549
    Durham NC
    You pay what you want from what I see that's not making any difference on any of these transmissions or vehicles lasting any longer That's for sure other things happen way before any transmission madness and something happens in the transmission it's usually MG1 or two which don't really use any transmission fluid I think that's what they're trying to keep the transmission fluid away from.
  18. ChapmanF
    15,402
    The oil isn't kept very far away from the MG windings; it is directed onto them to cool them.
  19. Tombukt2
    8,876
    1,549
    Durham NC
    I thought the big deal with the Toyota CVT fluid was its anti-fire catching capability or something along those lines not so much that the fluid was that much better pumped better or was a better transmission fluid it just meets the standard of not being electrically conductive or something along those lines?
  20. ChapmanF
    15,402
    It's not about fires. Electrical conductivity is the right general idea, but conductivity of the fluid isn't really the question.
    Motor windings are copper wire baked in an insulating varnish. It doesn't matter much whether the oil conducts, because, after all, the windings are insulated already. If they weren't, the MGs would never have worked from day one.
    It does matter what the oil does to the varnish, though. If the varnish deteriorates, you can get a P0AA6 code, or a burned winding spot (or both). It won't be a fire per se (though a burned-out winding can look pretty crispy). It just won't be conducive to driving the car.
    douglasjre and JohnPrius3005 like this.
