Is vent mandatory for 12v battery?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by codenamem27, Aug 28, 2020.
Tags:
  1. codenamem27
    codenamem27 New Member
    Australia
    2013 Prius v wagon
    Hi guys,
    Recently I purchased a new 12v battery (SuperCharge MF55B24R) for my 2013 Prius V. During installation, I noticed the new battery doesn't have the vent hole, which can be connected to the vent tube. Does it mean I have bought the wrong battery or it is just not required? This is the second time I change 12v battery, the previous one was Panasonic N-S42B20RHV which does have the vent hole, though it only lasted for 20 months.
    I am from Australia.
    Thanks in advance.
  2. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    My 12 volt doesn't have a vent on it...... Came from Autozone and cost close to $200 usa.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    The vent will function ONLY in very unusual circumstances.......like a huge overcharging voltage or a really bad crash.
    So no, as a practical matter, it is not "required" in normal operation.
    Before you paid AutoZone $200, did you check with a Toyota dealer ?
    Seems like I remember the price being a little less than that.......for some models.
    Tim Jones likes this.
    49,440
    depends on your safety comfort level. nothing is mandatory when you diy your own repairs
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    If you drive alone in your car, the lack of a vent only puts you at risk. (and as noted, it is rare to either create hydrogen gas or airborne sulfuric acid)
    if you travel with others, you also putting them at risk.
    Hydrogen - Wikipedia
    Sulfuric acid - Wikipedia
    Again, neither of these is likely if your voltage converter is working perfectly, but they are why the battery is vented.
    As noted Hydrogen gas burns with an almost invisible flame. I watched folks in our HS chem lab set fire to their station without realizing it.
    Thankfully I have no experience with sulfuric acid as an aerosol.
    Hobie18 likes this.
  6. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    And whoever else is on the road or nearby. If you succumb to the gases while driving others would likely be at risk.
    Since you are defeating a safety function you car insurance company could reject any liability.
  7. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    This was 2 1/2 years ago and I was out of state traveling and my inverter went out. Didn't know what was wrong so tried a new 12 volt battery. I'll have to look at it again but don't get in there very often.
  8. sam spade 2
    7,035
    2,788
    2017 Prius c
    And again AGAIN:
    An AGM battery does NOT release any harmful gasses except in the most extreme circumstances.
    And there would be other indications to warn you.
    Like many of your electrical system suddenly ceasing to work because they are fried by high voltage......OR hearing a loud bang and a crunching sound because your car has hit something hard.
  9. fuzzy1
    10,167
    Don't forget a potential third emission, even less common (indicative of a fairly serious electrical failure) but more toxic: hydrogen sulfide.
    Prodigyplace likes this.
