Is Vitroleum too good to be true?
Discussion in 'Environmental Discussion' started by Sufferin' Prius Envy, Jul 11, 2008.
  1. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    "The “Rivera Method” takes such agricultural refuse as cracked soy beans, rice and cotton seed hulls, grain sorghum, milo and jatropha and turns them into bio-crude oil. This crude – or Vetroleum, as Rivera calls it - can then be further refined into everything from gasoline to jet fuel and just about every petrochemical in between.
    With this process, just one bushel (60 pounds) of organic waste can yield about six gallons of bio-crude, Rivera said.
    What’s more, Rivera claims that products made from Vetroleum burn at near 100 percent efficiency, leaving behind neither heat nor pollution as proof of the chemical reactions taking place."
    Houston Community Newspapers Online - Green fuel, made at home
    Well, wouldn't that be cool. :)
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This line alone guarantees that the statement is untrue. This is not possible with any fuel.
    Tom
  3. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Sounds like some sorta pyrolysis process until the line that Tom pointed out. That sends up a rather massive red flag.
  4. tripp
    4,717
    79
    Denver, CO
    Besides anything with Geraldo's name on it has to be suspect.
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    Unless its a new line of throwable furniture. :D
  6. tripp
    4,717
    79
    Denver, CO
    :D:D
    Brilliant, mate. Brilliant.
  7. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    There's at least one blogger (not that that's defnitive, I know) calling this "vetroleum" a ponzi scheme, and he makes a pretty good case for it.
    Nom de guerre: Rivrdog: Scam alert!
    First it was "Carbon Credits", the Ponzi Scheme of all time, now it's "Vetroleum"
    Read this article. Read it knowing it has been written to bamboozle the reader.
    Let's take some principles of the old "snake oil" type of scam and see if we can find them here.
    1. Find everything a new name to make an older process (in this case, making biodiesel) seem like a breakthrough. We start with the very catchy word "Vetroleum". No, that's not correct. we should start with the reference "biocrude". It doesn't exist. Crude oil is a specific substance, namely petroleum oil pumped right out of the ground. It is "crude" or un-refined. There is no such thing as "bio-crude". If you are going to make biodiesel, you start with raw materials called biomass. At some point in your very long (not "8-minute") reaction, the substance you are cooking down in the presence of reagents, at high pressure, takes on characteristics of a long-chain oil molecule. You may then refine that substance, once it is fractionated (distilled and the fractional compounds removed) in the process (which is not called a "time reaction", it's Catalytic Cracking) into other products (in this case, they seemed to have refined it down into a form of volatile fuel usable as gasoline, but that is a HUGE waste of time, refining equipment and energy, it should be left at the earlier state where it resembles diesel).
    More analysis at the link.
  8. tripp
    4,717
    79
    Denver, CO
    I disagree with that blogger. It was be a load of shite (probably is) but it's not talking about biodiesel from what I can tell. Like I said earlier, it sounds more like a pyrolysis/FT process which DOES lead to a biocrude and hence can be refined into all sorts of petrochemicals. Again, it sounds bogus, but we're not talking about biodiesel here. The claims are utter tosh so I'm sure it's snake oil (bio snake oil, at least ;)).
  9. MegansPrius
    2,437
    27
    Chicago, IL
    Ah, well, there ya go. That's what I get for rushing and cross-posting something I hadn't check out myself. Thanks tripp. ;)
    With an eensy bit more digging, it does indeed seem likely this thing's a scam
    Judge OKs Rivera fraud suit
    A judge denied a motion to dismiss a lawsuit against local biofuel developer John Rivera Thursday. A Canadian company, Noront Recycling, filed suit in chancery court against Rivera in early August for alleged fraud, among other things.
  10. tripp
    4,717
    79
    Denver, CO
    Yeah, there was little doubt this guy is a complete tosser. The sad thing is that people were duped it would appear.
  11. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Vitroleum is too good to be true, that should be obvious. Nothing wrong with turning a waste product, like offal, into a synthetic crude or synthetic fuel. Beats dumping the stinky mess into a landfill. But don't expect it to displace more than a tiny fraction of our current oil need
  12. dogfriend
    7,512
    1,185
    Carmichael, CA
    I would like to see someone come up with an economical process to convert PE plastic bags (like you get at WalMart, et. al.) into fuel. Preferably this process could be done at home in a relatively safe manner. I have way too many of those f'ing plastic bags.
  13. dragonfly
    dragonfly New Member
    2,217
    There is. It's a revolutionary method called called plasticeum refining. With this method, you can turn one ounce of plastic bags into 5 liters of crude-gas. The black color is proof that it is crude. The floating around in the air is proof that it is gas. The method leaves behind a compact residue that can be used as compost. My tomatoes won first prize at the county fair last year, grown in nothing but crude-solids. When I tell people about it though they call me a liar.
  14. qbee42
    18,058
    3,074
    Northern Michigan
    This is easily solved. Take reusable bags when you go shopping. It's simple, cheap, and something you can do right now to help make a difference.
    Tom
  15. dogfriend
    7,512
    1,185
    Carmichael, CA
    Yes, I know. I have some reusable bags, but often forget them in the car. Old habits die hard. Plus, I'm looking at this as a "free" source of fuel; you can get those bags for freeeeeeeeeee..........
  16. dogfriend
    7,512
    1,185
    Carmichael, CA
    A Google search came up with no results. Do you have any links or other info?
  17. tripp
    4,717
    79
    Denver, CO
    dragonfly's putting you on, mate.
  18. dogfriend
    7,512
    1,185
    Carmichael, CA
    Yes, I expected so, but I wanted to believe. :p
    Sort of like how the Ford Explorer people I know want to believe in HHO. ;)
  19. dogfriend
    7,512
    1,185
    Carmichael, CA
    Getting back to the plastic bag problem - I understand that you should refuse the plastic bags that every store is pushing and use cloth (or otherwise reuseable) bags, but unfortunately, virtually all of the stores are pushing these things at you like some kind of plastic meth dealer.
    I recycle all of the plastic bags we accumulate by taking them back to the store (at least in Calif, the grocery stores will take them back) but it is kind of a pain and there is no guarantee that they still won't find their way out to the Pacific Trash Vortex.
    My thought on this is if you could convert them into something useful, you could keep them out of the waste stream and give them some value so that people would be reluctant to throw them away. If the raw material was valueable enough, maybe it would be worth someone's while to go clean up all the plastic already floating out in the Pacific.
  20. tripp
    4,717
    79
    Denver, CO
    Yeah, I hear ya. What's HHO, BTW. LOL.
    Stores here in Denvah are starting to hawk cloth bags and you get a $0.05 refund per bad that you don't use, so they even have an ROI. I've noticed more and more people walking into the store with bags in hand, which is a positive sign. Still, the bloody things are ubiquitous and, during the winter, it's not uncommon to see them flying like semaphore flags from the tops of trees.
