Is your grill unblocked yet?
Discussion in 'Gen 3 Prius Technical Discussion' started by cyclopathic, Mar 15, 2012.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    The temps got up we are expecting ~80 for next 8 days with mid-50s for low. Probably not warm enough to unblock grill yet.
    50% of lower grill blocked at Nov oil change, and the avg MPG through winter was 58.4 calculated.
  2. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Still fully blocked on bottom Here in PA, even though it's 70 degrees today. Still no issues. I think I could leave it blocked all year according to temps on scanguage.
    REV
  3. smokiejoe
    smokiejoe Member
    178
    30
    PA
    No Scangauge here, so I pulled off the foam pipe covering last week when temps got close to 70F, just to be safe.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I did not block this 'winter', never had any cold days.
  5. fuzzy1
    10,433
    Still fully blocked here. A warm snap has pushed the porch temperature all the way up to 44F. A hint of snow down here yesterday, pouring rain today, both mountain passes closed for avalanche control.
    With a ScanGauge and a very cool summer last year, I didn't remove the last half of the grill block until traveling east of the mountains in September. And it stayed out only two weeks. But as usual, our Pacific Northwest weather was the opposite of what most the the country was experiencing.
  6. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Pulled blocking off yesterday when temps got into the mid 70's.
    Will store the material in the trunk's under-cubby.
  7. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Pulled my grill block completely this morning. Highs will be 70F+ for the next week or more. When doing highway driving my scangauge shows fWT is exceeding 205F. Not sure if that is critical, but the scangauge does NOT show inverter temp and I have no desire to replace an expensive part like the inverter.
  8. SSPigboat
    SSPigboat Junior Member
    Illinois
    Is this something that's required to be removed? I don't rember reading about that in the owners manual.
  9. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    No, this is something that those of us who are upset with lower mileage in colder weather do to mitigate the effect cold has. We block off all or most of the air inlet grills to keep the cold air from cooling off the engine too much and causing it to have to run more, lowering MPG. The trick is in remembering to remove the block when the weather gets warmer so as to not overheat the engine or electric inverters. A Scanguage can be used to watch the engine and inverter temps, but you have to remember to watch it.
  10. Sabby
    Sabby Active Member
    295
    127
    SoCal
    Took it off earlier this week as I saw the temps rise toward 70's. With the warm weather I have seen a nice mileage jump
  11. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I've still got half the lower blocked here. I removed the other half of lower this week when we hit 70s for the high. Still a chance I'll have to put it back, but I think we're mostly out of the really cold temperature range here, except maybe the random low temp here or there. At this point, I'll probably remove the last piece in a couple weeks.
  12. cyclopathic
    3,292
    547
    2014 Prius c
    It hit 84 here, and we less then 100mi apart. I probably remove mine when I need A/C.
  13. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    I went full blocking from mid-winter till last week.
    Now full blocked down grill and removed upper.
    I am monitoring with scangauge-E the water temp and I found that with full blocking ... the afternoon I was reaching 195-198 very quickly and even gliding would not cool it down ... put on the heater and open the window (it was a few 50+ days here in NYC)
    Since mid last week I am running lower fully blocked. I found that this is safe if you can monitor your temp till you would need AC (see another thread about why).
    The morning gains still worth it ....
    If you have no way of monitoring I would not recommend this when average daily temp gets to mid 60s...
  14. szgabor
    994
    175
    Oceanside NY
    WOW nice mpg !!! my calculated just shy of 50 ... how are you driving like that
    I listen Marley (if I am alone in the car ... that is the only CD ....) So maybe "I am running like lion in Zion" too much
    Nice avatar !!!
  15. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Average high for time of year around 40F, average low is 20F, but the temperatures have been above average, although the mornings have mostly been high 20s or low 30s with just an occasional day in the 40s.
    Because of the higher-than-average temperatures I might take off one of the Advanced Warm-up Assistance Devices for the weekend, just to be absolutely safe since I'm not monitoring temperatures.
    (Nearly back up to 50mpg this last tank. I'm sure I would have done with summer tires on.)
  16. szgabor
    994
    175
    Oceanside NY
    This is your car but you can easily leave it .... Prius III has additional fans to help cooling which engages around 195-198 ... (of course blocking lower the efficiency of that ... )
    Unless you are running under heavy load (many passenger or stuff or a lots of uphill ) you should be just fine till mid-high fifties during the day .. the morning (and possibly late evening gain well worth it) also if you drive several shorter trip rather than 50 mile highway each way ....
    Again this is your car...
    Cheers
  17. cyclopathic
    3,292
    547
    2014 Prius c
    part of it the speed limit on my 15mi commute is 35-40-50mph and with speed traps it does not make sense to drive much over. Other part is Michelin Energy Savers, higher pressure, ECO and partially blocked grill.
    yes it is Bob Marley (hope noone assumed it is me!) it is been a while since listen to reggae, I go through phases. I've been listen to blues lately..
  18. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I keep the bottom blocked year round. I pulled all but 1 piece (each side ) from the top when OAT started reaching into the 50's. Coolant temp isn't the issue as fully blocked it wouldn't get above the mid 190's even in the summer. However, inverter coolant temp rises dramatically. "Normal" inverter temp is ~ OAT +20. I'm looking to keep inverter temp under 100F.
  19. szgabor
    994
    175
    Oceanside NY
    Just curious how can you get that info ??? I would be very much interested because heat is a HUGE factor of electronic "ageing"
    Cheers
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I can't do any grille blocking until I get the new tires broken in and all the gas mileage testing completed or I'll skew the results. :(
    I took the grille blocking off the GENII last month when temps were creeping into the high 60s.
