Is your mirror up-side-down?
Discussion in 'Gen 2 Prius Main Forum' started by brasche, Mar 13, 2006.
  1. brasche
    brasche Member
    156
    Orlando, FL
    Recently posted on a Yahoo group was a suggestion that tall drivers to turn the mirror up-side-down. At 6-foot-2, I think this is one of the best tips I've read!
    Not only does the morror coverage more closely match the rear window shape, it also improves visibility through the front and better positions the auto-dim sensor above the rear window cross bar!
    YMMV
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    I've heard this tip many times in the last two years. I did it once ( i'm 5'11) and it didn't work for me. I have a greater chance of light hitting the mirror right side up right now. When i turned it upside down, it did help.. but not as often. only if they put a "one way mirror" sensor right in the middle.. where it matters.
  3. Tideland Prius
    16,445
    no. mine's just raised to the highest position (incl. arm).
  4. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Yep, I flipped mine upside down a couple of months ago. I did it to get the auto-dimming sensor above the bar. I also put a piece of blue masking tape over the front auto-dimming sensor (on the back of the mirror) to increase the sensitivity of the mirror. At times it still doesn't dim as much as I'd like, but it's better, although I get a bit of a green tint sometimes during the day, particularly on rainy days or at dusk.
  5. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    I did this when I first got my Prius because I can see better out of the front
  6. darelldd
    6,059
    389
    Northern CA
    Just tried it, but I only drive once a month of so... :)
  7. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    This is a good idea, one I hadn't seen before. I don't have an auto-dim feature, so that part might be confusing to other drivers (my wife), but otherwise this is really helpful, and I'm not even that tall (5'10" or so, 178cm). But the mirror was definitely blocking my forward vision, at the point where cars entering from the right at an intersection were sometimes hard to see. I had already lifted the arm as far as it would go, which helped, but didn't realize that simply rotating the mirror around would help like that. After reading this suggestion yesterday at lunch I immediately went out and flipped my mirror upside down. Then on the drive home, I didn't even remember I had done that until half-way home when I realized (at an intersection) that I was seeing the road easier.
    Now if we could do something about the thick front posts. But I guess the side airbags are in there. I do like the visibility when backing up, definitely safer than an SUV.
    nerfer
  8. BellBoy
    BellBoy Member
    220
    My mirror is upside down now...thanks for the tip! Makes a big difference to me.
  9. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    I tried inverting my mirror and didn't like the effect. For one thing, the anti-glare lever is too hard to reach when it's on top of the mirror. The inverting trick might work better with auto dimming mirrors and no need to flip a lever. Also, the mirror filled in the gap between the visors and made the whole windshield upper edge appear lower.
    The improvement in forward visibility was only marginal. I'm over 6ft and use a shallow pillow under my butt for thigh support, so in effect, I'm about 6ft 3in.
    Bob
  10. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    "Recently posted?!?!" It should be in the Priuschat FAQ - we talked about that trick a year and a half ago.
    It's a real good tip for those with the auto-dimming mirror regardless of how tall you are since it gets the light sensor out of the shadow of the rear spoiler.
  11. DaveSheremata
    DaveSheremata New Member
    249
    Arlington, Virginia
    Whoah... good thread. *Now* mine is upsidedown. Being 6'2", I really like it. The autodimming does seem to work better too. Thanks Brasche!
    Dave
  12. Tideland Prius
    16,445
    looks like we need to revive threads with tips and tricks every year lol.
