Issue after transmission swap
Discussion in 'Prius v Main Forum' started by Salopeck James, May 3, 2023.
  1. Salopeck James
    Salopeck James Junior Member
    16
    United states
    I had leak in my transmission, I swapped it out with a same year Prius v that was rear ended and the transmission only has 62k miles on it. After the install all is good EXCEPT the transmission doesn’t seem to let the car go fast. It is like it has a computer control issue . It’s like in eco mode ev mode . Both lights are on . Does this transmission need to be reprogrammed to be controlled by the main ecu ? If so should I take to dealer to have them update this?
  2. ChapmanF
    15,621
    Nothing about the transaxle itself is programmable. It's two dumb motors and some gears.
    Can you post a video of what's going on?
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,977
    4,717
    Texas Hill Country
    Hopefully it was not from a Prius v wagon. They were not made in 2010.
