Issue with JDM Steering Wheel
Discussion in 'Gen 3 Prius Accessories and Modifications' started by The Critic, Feb 2, 2013.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    I just installed the JDM steering wheel
    Unfortunately, as some of you are aware, the splines are not quite identical to the original steering wheel. The steering wheel ends up either slightly off-center to the left or to the right; there is simply no way to center the steering wheel. I r/r-ed it twice and arrived at that conclusion.
    At this point, my only option is to adjust the tie rod ends to center the steering wheel. However, wouldn't this make my steering rack go off-center?
    The steering wheel is not off-center by a lot, but I think it's a good 1cm away from the center (9&1 vs 10&2).
    Per the FSM, you can have a 1.5mm difference (1-turn of tie rod) between the length of the left and right tie rod and still be OK. Obviously, this is going to require more than that.
    Thoughts? For those of you who had the off-center steering wheel issue, did adjusting the tie rods cause major issues?
    Thanks.
  2. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    I don't see any downside to the steering rack being off enter by that little. AFAIK lock-to-lock travel isn't usually limited by the steering box or rack & pinion unit--it should be a hard stop where the steering knuckle contacts the lower control arm.
    I'll look around for photos of Prius front suspensions to see if I can find an example.
    - Chris
    [Edit: it looks like the most likely stop is between the steering knuckle and the casting that holds the lower ball joint. I'd take a picture of my own car's front end but it's a little cold out right now.]
  3. The Critic
    3,193
    2,321
    CA
    Thanks Chris. This is how far off it is. ImageUploadedByTapatalk1360143494.282098.jpg
    iPhone ?
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Nice looking wheel! That should be easily corrected at the tie rod ends.
  5. El Nino
    El Nino Member
    210
    Michigan
    That is WAY off center from my install and others I have seen. It almost looks like you are a full extra notch over. Did you mark center before removing the steering wheel to know what true center was? Total bummer because the JDM wheels are such an improvement.
    ucsmfu likes this.
  6. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    El Nino, you going to ToyotaFest ? Hope to see you around when i come down to Cali in May :p
  7. The Critic
    3,193
    2,321
    CA
    Yes, I did mark the center of the wheel. I tried the three nearest positions and none of them are remotely close to center.
    I think I will try tweaking the tie rods first. Since I did mark the center of the shaft and the old steering wheel, if the box goes way off center, I have a means of return.
  8. ockevin
    ockevin Active Member
    493
    148
    Orange County
    mine is off by a millimeter or so...yours is way off....
  9. El Nino
    El Nino Member
    210
    Michigan
    That sucks..it has to be the wheel then that has the notches off because all the Pri should be the same? Can you return the wheel?
  10. The Critic
    3,193
    2,321
    CA
    I'm somewhat tempted to just tweak the tie rods since I think 1/2 turn should fix it. Per the service manual, you can have up to a 1-turn difference between the left/right tie-rods and still be within spec.
  11. ucsmfu
    1,498
    420
    canada
    was he patient in regards to your concern ?
    cause he wasn't with me, I experienced very poor customer service from him ><
  12. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    Again, with this winter's changeover from the stock rims and tires to the winter rims with Blizzaks, my 3rd party tire shop installed TPMS transmitters in the winter rims, balanced, and realigned (which of course included centering the steering wheel)... all for $99...
    Wouldn't you reckon each car is individually adjusted at initial assembly? I'll bet if you swapped wheels between two otherwise identical Prii... they'd be off center...
    I still take it as a minor irritation... my larger concern is that between the 100 degree summers and our below zero winters we get here in Maine, the wood/plastic is beginning to crack in various places... I'm ready for all leather... or maybe dispense with the driver's air bag and adapt my 40 year old wood and and aluminum Nardi wheel :)
  13. The Critic
    3,193
    2,321
    CA
    Chinesium parts....I should have known better. :censored:
  14. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Good point. That's what adjusting the tie rods is for.
    You may not fare that much better with Toyota parts either :D
  15. El Nino
    El Nino Member
    210
    Michigan
    I got my full leather Luna steering wheel from the Rakuten shop RS-Online[​IMG]I choose the black leather with black stitching and I really love it. Extremely comfortable in the summer and winter. Only a couple hundred dollars and then your Tenso fees which are on sale for half off now.
    cycledrum likes this.
  16. El Nino
    El Nino Member
    210
    Michigan
    I wish! Never say never though as I may be back in the area in May..not sure.
  17. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I hope it's fixed now because that wheel looks sweet!
  18. The Critic
    3,193
    2,321
    CA
    Adjusting the tie rods did the trick. It took just under one full turn of the tie rod on each side. Now I just need to do a zero pt calibration and I will be set.
    F8 L gets to inspect it later today...
    iPhone ?
  19. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The wheel looks awesome. Keep it, bro! :)
  20. ucsmfu
    1,498
    420
    canada
    I'm having an issue, when I make a left or right with the steering wheel it makes a metal rattling sound, sounds like keys clinging, anyone notice this issue with their JDM steering wheel ?
    thanks
