Issue with outside vent?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chkcee, Mar 20, 2015.
  1. chkcee
    chkcee Junior Member
    Los Angeles
    Recently I've been noticing that even though my vent is in the circulate position, I can still heavily smell odors coming from the outside. I vacuumed the inside of the cabin air filter box, vacuumed and removed everything from the outside front cowl, and replaced the air filter. Still have the smells coming through. I'm thinking the vent(s) do not close properly. Anyone else have this issue? Any fixes? Thanks
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    If I'm not mistaken, outside air is still taken in when recirculate mode is engaged. Not sure of the percent split though.
  3. mrbigh
    3,686
    699
    Long Island, NY
    Interesting topic.....
  4. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    You are correct. There is always a small amount of outside air entering the cabin to prevent possible condensation.
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    And to keep a slight positive cabin pressure to help prevent exhaust infiltration.
  6. chkcee
    Los Angeles
    ah ok, thanks guys. going to purchase a better cabin filter and see if that solves it.
  7. xliderider
    7,869
    3,116
    Honolulu, HI
    They sell cabin filters with activated charcoal that supposedly help control odors.
    And there's always the clip on vent air fresheners. ;)
  8. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    True, and one reason many American cars, at least in the past, didn't provide a "recirculate" setting.
    It would be interesting to know the percentages of outside vs. recirculated air in the fresh vs. recirculated settings. Neither is really 100% what it says.
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The Dust and Pollen button will provide a tight shutoff for only 3 minutes if you need a quick air block. It is meant to circulate air inside the car and remove the dust and pollen.
  10. bisco
    49,466
    what would you breathe if there were no fresh air?
  11. Easy Rider 2
    1,584
    257
    Ocala, FL
    What ? Where ?
    More information please.
  12. jdcollins5
    5,131
    1,338
    Wilmington, NC
    On the Gen III there is a Dust and Pollen button on the Climate Control panel. I am not sure about the c.
    This will close the outside air vent tightly to circulate cabin air through the cabin air filter to remove any dust or pollen inside the cabin. It has a 3 minute timer so you will not forget to turn it off.
  13. Easy Rider 2
    1,584
    257
    Ocala, FL
    Including current production models ?
    No, the C doesn't have that and I've never seen one before on any brand or model.
    I assume that is in addition to the recirc. button and not instead of.
  14. jdcollins5
    5,131
    1,338
    Wilmington, NC
    This button is right beside the Recirc Mode button.
    It was on the Gen III Liftback models beginning in 2010. I do not know about current models.
