Issues after 1st oil change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by barenakedbubba, Dec 31, 2007.
  1. barenakedbubba
    barenakedbubba New Member
    A month ago, I had taken my Prius in to the dealer for it's first oil change. (I had a free coupon.) I've noticed that my MPGs have dropped slightly since getting the car back. (approx. 48 MPG to 45 MPG) And also, there have been a couple of times where I'm sitting stopped, and the gas motor starts, but it does not show on screen that it's charging the battery. In fact, once the battery was in the green zone when it happened. Is this something that's normal? Should I bring it back in to the dealer? (What could they have screwed up?) The only thing that I can think of is that it's been a little bit cooler than before my oil change. (I live in LA.) Thoughts? Thanks in advance!
  2. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    I also had a drop in MPG from 54.5 to 51.2.
    I saw they overfilled my oil and lowered my tire pressure from 42/40 to 32/34.
    Hope This helps
    As far as the battery etc. I haven't a clue.
  3. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    I've experienced the same thing with my Prius, but I do not worry too much about it. After a few minutes of driving, everything is indicated back to normal with a full charge on the batt. My MPG fluctuates from 46 down to 42 then up again to 45 MPG.
    I plan to change my oil at 3K, since this is going to be my first. 2.2K so far on the odo. Enjoy your Prius.
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I believe the ICE will start but won't show a charge when the battery is in the green, it only starts for the heater, I bet if you shut the heater or A/C control off the ICE would have shut down.
  5. beboyle
    beboyle Junior Member
    39
    Phoenix
    You don't say where you're located, but if you are in a place where cold weather started about a month ago, that's likely to be the biggest cause of your mileage reduction. Based on reports from many PriusChat members in colder climates, the mileage can drop significantly when the weather cools off.
    That said, checking your tire pressure and oil level is a good idea anyway. There's some debate about how much effect too high an oil level will have, but low tire pressure has a very direct impact on MPG.
  6. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    Yup. Here in Minnesota, my efficiency has dropped all the way down to 44 MPG! ;)
    Sadly, that is actually down quite a bit from the low 50's I enjoy during the summer... but still way above most every other vehicle on the road.
  7. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    This is what we console ourselves with, too.
    The Prius is still getting double the MPG of our other car, even in winter :)
