Issues starting to creep up.....
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ivanhoe, Nov 8, 2021.
  1. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    My 2015 V is starting to have some strange issues creeping in. First off it started as follows;
    1 When coasting down a long stretch of a highway hill, ICE is off and I'm gaining speed and all of a sudden the ICE would kick on for a second and switch back off! It does it once in awhile and not all the time.
    2 After I start the cold(or sitting for awhile)vehicle and start my journey on the highway and slowly accelerate to speed, I would get a sudden acceleration(like giving more gas) without any difference of gas pedal movement! Usually happens around 40km/h or so. I live next to a highway if you're wondering with a slight incline in the beginning.
    3 I'm starting to have a Key Battery Low Voltage Message and voltage is at 12.3V. I went to try it to see if the hybrid system is charging it but the Key Battery Low Voltage came on for the first time at start, :(
    With these issues happening, the question is it all related to a Key Battery Low Voltage state?
    I'm trickling a charge with my Ctek 3300 Charger as we speak.
    Starting a search for a replacement battery, I like the BOSCH S6535B or go back to OEM which only lasted 6-7 yrs!
  2. Air_Boss
    Air_Boss Senior Member
    4,139
    1,154
    New Yawk
    The key battery is a 3V button cell in the key fob.
    ivanhoe likes this.
  3. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    That sounds like good news, I've got spare batteries in the glove compartment just for that situation. Crossing my fingers for the easy outcome, Thank you!
  4. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    #1. Normal operation. Electric motors do not like no/low load situations. Therefore the ICE will kick in on all the PHEVs I've driven on mild downward slope and light pedal. As evidence whenever you put them in N the engine will not start to charge the HV battery.
    REVVL V+ 5G ?
    ivanhoe and Air_Boss like this.
  5. Air_Boss
    4,139
    1,154
    New Yawk
    Above 42-43 mph indicated, the ICE will kick on to prevent MG1 and MG2 from over-revving.
    ivanhoe likes this.
  6. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Finished the trickle charge and replaced my key fob battery. The vehicle started at first attempt and the hybrid system is sending 14.7V to the smaller trunk battery. Tomorrow morning will be a more of a normal start situation and anxious to find out ;)
    jzchen likes this.
  7. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    No problems this morning on startup and the lengthy hwy excursion :)
    Air_Boss likes this.
  8. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Checked the voltage on the trunk battery, 12.2V :(
    I got a feeling it's on its way out.
    What are your thoughts?
  9. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    I don’t know if you checked the voltage under the hood at the jump point or on the battery itself. But that definitely seems low.
    ivanhoe likes this.
  10. Air_Boss
    4,139
    1,154
    New Yawk
    Were you operating with a lot of electrical loads? Lights, fan, a/c or heater?
    ivanhoe likes this.
  11. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Long highway drive yesterday and checked battery early afternoon. No heavy electrical load during the drive. Haven't started the vehicle today.
  12. Air_Boss
    4,139
    1,154
    New Yawk
    Ambient temperatures during the drive and battery check?
    ivanhoe likes this.
  13. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    About 12C (54F) for drive and 6C (44F) battery test on battery.
  14. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    Our 2011 Prius' original 12v auxiliary battery died 6 years in. Yours is nearing it's serviceable life.
    I'd get a replacement for it before it strands you somewhere cold and remote.
    ivanhoe likes this.
  15. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    I'm thinking alike, the search is on (y)
  16. Air_Boss
    4,139
    1,154
    New Yawk
    Oh, I missed that it was the original 12v auxiliary battery. Yes, at six years, you are driving on borrowed time.
    ivanhoe likes this.
  17. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    My 2004 Sienna battery(Delco) lasted 14 yrs(y)
    Pricier AGM's not so much o_O
  18. Air_Boss
    4,139
    1,154
    New Yawk
    They don’t make ‘em like they used to… anything.
    bisco and ivanhoe like this.
  19. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Dealer wants 340 plus tax or 240 for a 4/21 Optima Yellow(6 months)!
    Decision, decision......
  20. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Oh forgot, made a service appointment for the software update as it was pointed out to me. Safety recall RA7
    Other warranty enhancements W48 and W51 was brought to my attention.
