Issues with AUX mp3 jack on Prius II
Discussion in 'Gen 3 Prius Audio and Electronics' started by Tall Rob, May 14, 2010.
  1. Tall Rob
    Tall Rob Junior Member
    I plugged my Blackberry Curve into the AUX jack inside the glove box, but when I hit the AUX button on the radio (this is base II radio, not JBL), there is no display of the mp3s, and none of the radio controls (ie: select arrows on the steering wheel) have any effect.
    Also, the sound it very, very low. I have to crank the volume up to 45 in order to even hear the music.
    Is this because I am using a Blackberry Curve as my MP3 player, or is the Base II radio just not set up for this?
    Any suggestions?
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    An aux jack is a simple audio connection. It transmits audio from one device to another. Nothing more, nothing less. The only thing you can control from the car is volume, and no artist/tract/etc. info is transmitted.
    If you had the USB port, you'd have more functionality, though I don't know if that's an option without the JBL system.
    Regarding low volume, try raising the volume on your phone.
