It’s hot in CA why does fan take forever to kick on after starting car?
Discussion in 'Gen 4 Prius Technical Discussion' started by 1stPriusLA, Jun 4, 2018.
  1. 1stPriusLA
    1stPriusLA Junior Member
    16
    Los Angeles
    Three Touring
    Since it’s been getting warmer in Los Angeles I’ve remembered what a pain it is for the AC fan to kick on after pushing the ignition. Why does it take close to 10 seconds for the fan to start blowing? I’ve been filling edited of my driveway down the road until it kicks on. 2 others have mentioned it to me in my car. Is this something Carista can take care of with the “Fan speed reaches its target” option? Thanks guys
  2. RRxing
    RRxing Senior Member
    2,516
    1,789
    NEPA
    If you have it set to AUTO it will take a few seconds for the fan to get up to speed, depending on your temperature setting. Taking it out of AUTO "should" let the fan speed up to whatever you have it set for. Don't know if it will be instantaneous or not. I just leave mine in AUTO, the slight delay doesn't bother me.
  3. Diemaster
    Diemaster Active Member
    290
    260
    so. cal
    I have noticed in my truck (2004 Toyota Tacoma) that when i turn the AC on it takes 10-15 seconds for the AC to start blowing cold. im assuming the car is smart enough to account for this so the AC can catch up and not blow hot air at you instantly.
    Valiant V and 1stPriusLA like this.
  4. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Exactly. People unfamiliar with Toyota's perceive this as a problem. Those that are accustomed to it, get really annoyed at other makes when renting those.
    When it is hot out, and you say "gimme cold!" the car gets the AC ready then slowly ramps up the fan to the speed it needs. Similarly when its cold out and you want heat, nothing comes out until the engine is warm, not even fan. It doesn't make sense to blow cold air at you when you say heat.
  5. bisco
    48,862
    it would be nice if the rear camera came on when you've put it into reverse, instead of after you have already backed up.
    kithmo likes this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    My A/C at home is like that - at least my newer one. To COOL, it opens the vents, and the outside unit blows through the condensor almost immediately, but it's about 20-30 seconds before I get cool air blowing inside. If it's on HEAT, it's about 50 seconds when it starts gently blowing, about a minute before it gives full air-flow.
    It's to pre-heat/pre-cool it to stop it blowing HOT when you want COLD, and COLD when you want HEAT - which is what the old big unit in the living room does (it's getting pensioned off next Thursday!!)
    RCO likes this.
  7. alanclarkeau
    7,041
    7,580
    Gen 4 doesn't do that.
    Valiant V, jerrymildred and bisco like this.
  8. bisco
    48,862
    great! about time.
    alanclarkeau likes this.
  9. Diemaster
    290
    260
    so. cal
    hes typing sarcastically. he means it takes so long for the infotainment system to boot up he's already done his backing up by the time the image comes on the screen.
  10. bisco
    48,862
    that is what i mean, but why infotainment? not being sarcastic.
    kithmo and alanclarkeau like this.
  11. Diemaster
    290
    260
    so. cal
    i just use that term instead of "the 7" screen in your 2017 prime plus or 11.6" screen in premium/advanced and all 2018 primes."
    kithmo, Merkey and bisco like this.
  12. alanclarkeau
    7,041
    7,580
    Oh - I've not really noticed it - I press POWER as I get in, shut door, then seatbelt, glance at mirrors, put in gear and it's usually ready by then. He must be quicker than me!!! I just timed it - it's about 7-8 seconds.
  13. bisco
    48,862
    yes, i have it in reverse in a second or two, then have to wait for the screen to come on. drove my dil's murano the other day, camera came on as soon as i put it into reverse.
    kithmo likes this.
  14. alanclarkeau
    7,041
    7,580
    Gen 4 won't engage a gear for maybe 5 seconds or so - comes up with upload_2018-6-5_10-56-41.png if you try and says "shifting unavailable" or something like that.
    Valiant V likes this.
  15. bisco
    48,862
    interesting. that would frustrate the heck out of me, would probably need some valium or something.:cool:
  16. Diemaster
    290
    260
    so. cal
    mine will shift as soon as the ready light comes on.
    apparently i can read bisco's mind.:eek: not sure if that's a good or bad thing. im seeing some weird stuff man....:D
  17. alanclarkeau
    7,041
    7,580
    Yep - I think there's a ready light - but I suspect it comes on while I'm belting up, closing doors etc - just occasionally I hit R or D before it's ready.
  18. bisco
    48,862
    bad, believe me. it's the lithium typing.
  19. Merkey
    Merkey Active Member
    250
    228
    Birmingham, Michigan
    what's a "dil's murano"?
    Raytheeagle likes this.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,474
    Bay Area, California
    2019 Prius Prime
    Daughter In Law’s Nissan Murano I believe is bisco’s short hand;).
    But I’m 3000 miles away guessing:whistle:.
    Valiant V, bisco and Merkey like this.
