It feels like I have to push the gas pedal harder to get up to speed.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by HoytHoytHoyt, Mar 25, 2013.
  1. HoytHoytHoyt
    HoytHoytHoyt Junior Member
    Atlanta
    The temperature has been in the lower 50's here in Atlanta. My C has 15,200 miles on it and it seems like I have to push the gas pedal alittle harder than normal to get it up to normal driving speed. My trip to work is 14 miles, Im usually getting 54 mpg, but over the last month it has been struggling to get past 50 mpg. Ive brought it to the dealer and they of course tell me that everything checks out ok, but I know its not running like it use to be. Im tryhing to blame it on weather, but for some reason I feel thats not the case.
  2. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    It drives like that in ECO. Normal. Check that.
    X
  3. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    As others have pointed out, make sure there is no obstruction of the cooling air vent for the high voltage battery back (driver side below the rear seat.
  4. HoytHoytHoyt
    Atlanta
    It hasn't been in ECO mode. The vent is totally free and clear.
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Is it raining? That will account for the difference.
    Have you checked the tire pressure?
  6. HoytHoytHoyt
    Atlanta
    Will the CPU account for weather change? How long will the CPU take to adjust to normal weather? 50 miles? Its suppose to be warming up here by the end of the week. It hasnt been raining. Is there such a thing as a CPU reset so it can relearn my driving habits or for the weather change? I just had it in for its 15k service and all of the tires are set to 38psi all the way around.
  7. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    My first thought was also ECO mode.
    I'd up that tire pressure a bit, personally.
    And, wait, the cooling vent for the battery is under the DRIVER? I thought it was under the passenger seat and the jack or somesuch was under the driver's seat...
    Also, that slight a dip in MPGs certainly could be due to colder weather. In my experience, temps in the 50s yield MPGs in the 50s (sometimes with a struggle). I get really good mileage in the 60s, great in 70s and above.
  8. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    dick_larimore mentioned it was "driver side below the rear seat", which is correct. The battery vent is under the rear seat, on the left-side of the vehicle (driver's side for the US, passenger side for us). Yes, this is the same side as the jack under the front seat (under the driver's seat in the US, under the front passenger seat for us).
    The difference between 50 and 54 mpg is nothing in my opinion... I have variations larger than that every day.
  9. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I see that just based on weather alone. I can get over 60 when the weather is above 50, but below that and I struggle to get over 50...:oops:
  10. RocMills
    789
    276
    Las Vegas, Nevada
    Battery vent is on left side... okay, I've been keeping the rear right side clear. And vent is under back seat not front seat. Sorry for derailing the OP.
  11. Former Member 68813
    3,524
    981
    US
    There is no adjustment for weather. Colder temps = lower engine efficiency and energy siphoned to heat the cabin. Simple laws of physics.
