It is possible to program a used silver key with techstream.
Discussion in 'Gen 2 Prius Main Forum' started by Calimobber, Feb 15, 2020.
  1. Calimobber
    Calimobber Member
    94
    82
    Death Valley
    I programed my used key today and just wanted to put the information out there since It took me most the day sorting out all the old/bad techstream info for regestering a used prius key.
    YES it is possible to register a used key purchased off ebay or other. You will need techstream and a seed passcode. I paid $25 for 5 keys(each key works forever on one car. I used LEXUS, SCION, TOYOTA PASSCODE CALCULATOR / GENERATOR: Calculate Pass-code by Seed number | Immobilizer Pincode Calculator (official website) and it generated a key instantly). I have 3 more if anyone wants to buy one for $5 each.
    Once you get techstream with a cable and you have a Seed code you will need to reset the immobilizer codes. This puts the car into auto register mode and I just inserted one key into the slot and pushed power, then turned off and put the next key into the slot and hit power. This registered my old key and the new used key I found automatically.
    Then you can go into smart key register and register the keys so the sks functions work as well as the wireless door locks/unlocks.
    There is a few other ways to do this but it seems the most important thing with the used keys is just resetting the immobilizer keys. Im sure this will confuse alot of people but ill try and help anyone who is trying this.
    thanks226, Mutual, Salvage09 and 2 others like this.
  2. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    Wow, this is one of the best posts I've seen on this subject! Thanks!
  3. Calimobber
    Calimobber Member
    94
    82
    Death Valley
    I used the ebay key on my drive to work today and everything is working as it should.
    PriusCamper likes this.
  4. Salvage09
    Salvage09 Junior Member
    38
    Pasadena CA
    You've inspired me to get a cable and try this. If you still have codes, I'll buy a couple.
  5. PriusG8
    PriusG8 Junior Member
    does anyone know if a used key fob for a Prius 2010 model would need to be flashed or unlocked but one can use techstream to program it to a different Prius?
  6. Calimobber
    Calimobber Member
    94
    82
    Death Valley
    I dont know but id imagine no. Id stick with the 2nd gen remote.
  7. Blaz' Barton
    Blaz' Barton New Member
    Columbia, MO
    Did you have to have Techstream hooked up to the Internet to do this or did the pass code that you purchased unlocks it regardless? I'm about to do this to my wife's car. I would be willing to buy one of your codes if you still have any as well.
