It shows no signs of life
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dbd1964, Nov 21, 2019.
  1. Dbd1964
    Dbd1964 New Member
    Hawaii
    My daughter’s 2010 Prius shows no signs of life. Initially my wife had left the headlights on for a long time and drained the battery. We took it to the shop my daughter bought it from and they gave us a temp replacement, they test and checked the the battery and recharged it. Said it was fine.
    So with a full charged temp loaner battery - No lights, key fobs not working, car won’t start unless I have jumper cables on it.Then all the initial things that light up, operate without starting the car are working and the car starts fine but as soon as I take off the jumpers it dies.
    If this were any car but an electric I would think I had a dead battery and bad alternator. But the battery is known good. Tried two of them
    Any help would be greatly appreciated. Seems like a fuse is blown right near the battery’s output feed but I have no idea where that would be or what it would look like. I changed the battery twice so I do know where the battery is. :
    Thanks
    Dan
  2. schja01
    schja01 Senior Member
    1,820
    1,207
    Chicagoland
    2024 Prius
    Limited AWD-e
    Bad cable or clamp or connection at far end of the battery cable(s)?
    jerrymildred likes this.
  3. Mendel Leisk
    40,574
    Trust but verify.
    Raytheeagle likes this.
    51,141
    welcome!
    if the jumpers are on the battery posts, i can only think the 12v is so defective, it is somehow interrupting the inverter flow.
    if the jumpers are on the jump point, the problem is somewhere in the back. battery/fuse/connections
    but are we missing a piece of the puzzle? they installed a 12v loaner and it started and ran fine?
    you drove home fine? the next time it was dead? or it worked for several hours/days/weeks?
  5. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Parasitic drain
  6. bisco
    51,141
    dang parasites!:mad:
  7. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    Tighten battery terminals and the ground cable from battery to car chassis.
  8. Dbd1964
    Dbd1964 New Member
    Hawaii
    No. Drove a different car for the battery loaner. The loaner was fully charged but did not start the car. No lights came on, nothing
    Thanks
    Da
  9. Dbd1964
    Dbd1964 New Member
    Hawaii
    No we drove a different car to pick up the loaner. The loaner battery didn’t start the car. Not a single light came on. It’s like the battery wasn’t even vonnected
  10. bisco
    51,141
    pur a meter on it
