It sounds like it must be the Brake Actuator/Booster, C1391
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Brunto, Oct 2, 2024.
  1. Brunto
    Brunto New Member
    Houston
    2013 Prius C
    195k miles
    Houston, TX
    No major repairs
    New NiMH battery as of Feb 2024
    Significant FL quarter-panel damage from a side-swipe
    Error code C1391
    So about a week ago, the brake pedal lost almost all of its resistance while driving. I assumed master cylinder, but in researching, looks like for a Prius, it's actually the brake actuator/booster. [Master cylinder is contained inside the BA, I guess?]
    I understand the code specifically identifies a detected leak/loss of pressure inside the unit. I also understand this could either be inside the actuator or the pump/accumulator.
    I've watched a few videos, and the replacement doesn't look overly advanced. Tedious and long, but doable. It's the calibration at the end of the process that all of the DiY video-ers discourage for at-home repairs. Everyone says you really need to take this in to get it done. And that appears to mean anywhere from $1500-$4k, depending.
    I've got a handful of questions:
    • Is 200k nearing EoL for a Prius C?
    • In anyone's opinion, is a likely $2k+ repair worth it, at this point? Or is this the beginning of a series of failures, now that my car is this old?
    • Or... (and this is my hope... haven't had a car note in 8 years), do these little buggers typically chug along for 250k, like many Toyotas?
    Or...
    • Is this a doable repair in my driveway?
    • If I buy a Techstream device, can a rank amateur work out the bleeding down and calibration of the brake lines?
    • I see most Techstream devices are pretty friggin' expensive. Are there any devices that would accomplish this that aren't going to break my small bank?
    • It looks like the parts (when bought through reputable sources) average about $1400 together. Any pro-tips on affordably sourcing these parts?
    Thanks a ton for reading and helping!!
    Grace and peace,
    Matt
    #1 Brunto, Oct 2, 2024
  2. Leadfoot J. McCoalroller
    7,847
    7,315
    Pennsylvania
    2018 Prius c
    Toyota builds cars that last "about 15 years" with some of them making it towards 20. No-salt winters in your neighborhood would likely let yours go longer.
    It's on you to make the odometer read whatever you want before that clock runs out.
    The three most expensive problems I know of in these cars are the brake booster, the hybrid battery and the LED headlights. You already replaced the battery, you're having the brake issue now and they didn't use the LED headlights until around 2017 so you dodged that bullet.
    So from my point of view you aren't beginning a series of failures. You're already more than halfway through.
    Other DIYers have successfully done this repair. I'm not one of them, haven't faced the need yet.
    Some Toyota dealers operate online parts sales divisions. They tend to have much better prices than the walk-up counters at all the other Toyota dealers. Here's a link to one, there are others out there.
    I don't know if there's much percentage in trying a used part. From what I've read Toyota revised that device frequently, and there are known to be different versions of it for slightly different configurations of the car, so it's possible the only ones that interchange are exactly as old and used-up as what you have now.
    Just to clarify: a "Techstream device" is generally just an interface cable, more correctly known as a "mini-VCI."
    You'd plug that into the USB port of your existing Windows laptop and then install the Techstream app.
  3. Brian1954
    Brian1954 Senior Member
    1,767
    689
    South Central PA, USA
    Do you mean C1391 trouble code?
  4. Mendel Leisk
    40,559
    Not sure if I’m reading that right: are you saying that DIY’ing everything but the Techstream procedures at the end, a dealership would charge that much JUST to wrap it up?
    have you got any quotes for the complete job?
  5. ChapmanF
    17,282
    I'm pretty sure that code should be C1391, in the OP and in the thread title. If enough time has elapsed that the original poster can't fix them anymore, the Report button can be used so a mod can do it.
  6. Brunto
    Brunto New Member
    Houston
    This is all really helpful. Thank you tons, Leadfoot.
    I've got a buddy who's got a lot more shop experience than I do. We may tackle the replacement together. I've mostly been discouraged a bit about the price and the calibration stage. If I can justify the parts cost, I feel pretty decent about it. PriusChat always impresses me with how folks pretty consistently just throw it straight over the plate. If it's time to retire her, I trust I'll hear that here. Thanks for your counsel!
    On this note, we had seen some commentary online that there are a ton of bogus "Techstream" products out there, and that the software they come with is pirated—and oftentimes untrustworthy. I checked Toyota's site, and it looks like the license I'd need is only available as a 2-day or yearly license, and for either $70 or $1360, respectively. That's wild. Any experience with the "pirated" versions out there? I'd love to feel confident in an inexpensive tool.
    Matt
  7. Brunto
    Brunto New Member
    Houston
    Yes! Doh! My bad. Unless I'm missing something, it doesn't look like I can edit the post to correct it.
  8. Mendel Leisk
    40,559
    Likely past the edit limit, and definitely so for the title. Click the "report" button beside first post and explain.
    Again, have you just asked a dealership or three, for a "turnkey" replacement quote? That's assuming the brake components are determined to be defective.
  9. Brunto
    Brunto New Member
    Houston
    Fair question! No, I haven't gotten a quote just for bleeding/calibrating the brakes after install. Those prices are what appear to be folks' real experience getting this whole replacement done professionally. I assumed it might not be safe driving it to a shop? Are you suggesting it's sufficiently safe to drive it a few miles afterwards? I've only ever done brakes on my truck and an old Honda, with a buddy pumping the brakes while I manned the bleeder valve. Pump it out; fresh brake fluid; pump all the air out; drive. Never had a calibration process to wrap it up, so I'm obviously really green.
    Matt
  10. Brunto
    Brunto New Member
    Houston
    You're correct! My bad! Apparently past the edit window, so I'll report it.
  11. Mendel Leisk
    40,559
    I meant for the whole stem-to-stern job. Then compare to your parts cost, plus your skill level, the labour, and the not insignifcant hassle/expense of getting Techstream up and running. Lots here report difficulties post swap, the software stalling halfway through the bleed process. Consider too, if the dealership does the full job, there's no finger-pointing, it's all on them.
    It'd probably cost you at least a $100 for diagnostic, they don't do anything for free anymore...
    ("turnkey" might be a CDN expression, means basically a full start-to-finish job, more used in construction I think, where the contractor has the keys to a property, does a full job, locks the door on the way out and drops the key through mail slot. Something like that lol.)
    #11 Mendel Leisk, Oct 3, 2024
  12. Brunto
    Brunto New Member
    Houston
    I got it! We use that down here in the states, too. I was responding to your initial post—and mis-reading it along the way! I read it as though you were asking if I'd gotten any quotes for the wrap-up, post-install.
    I haven't taken it in, yet. The problem just started the weekend before last, and I've been doing some research in my spare time. Figured I'd get a general idea of what my options are before moving it out of the driveway. Definitely feeling like you're right: It's time to take her in for an estimate.
    Curiously, for about 5 days, the brakes seemed to be functioning normally, and the instrument cluster cleared up. No lights, no codes. It's possible the app I'm using cleared the code—though I was deliberately NOT intending to clear it, myself. I know those codes are there for a reason, and it's often a bad idea to clear them without addressing the reason for the code to begin with. Anyway... made me think for a minute that maybe it was just a sensor issue, or something. But the 1391 and loosey-goosey brake pedal came back this past weekend, and she's sat there ever since.
    Matt
  13. Tideland Prius
    16,443
    Fixed!
    Brian1954 likes this.
  14. Leadfoot J. McCoalroller
    7,847
    7,315
    Pennsylvania
    2018 Prius c
    Well I had a 32-bit pirate version running on my old Windows 7 netbook at least for a little while. It's not working anymore.
    I was using this with a Tactrix OpenPort interface. It's wonderful hardware but not particularly cheap. I originally bought it to flash custom fuel maps into the ECU of my turbocharged Subaru. Then later we discovered that it was a very good device for communicating with a modern Prius. Very trustworthy equipment.
